How to fix jumpy scroll wheel of a computer mouse
  1. How to fix jumpy scroll wheel of a computer mouse, How to fix jumpy scroll wheel of a computer mouse: step 1, image 1 of 1
    • Flip the mouse upside down and remove the screw on the bottom of the mouse casing using a screwdriver
  2. How to fix jumpy scroll wheel of a computer mouse: step 2, image 1 of 1
    • Remove the wire from the board by slowly pulling the connector
  3. How to fix jumpy scroll wheel of a computer mouse: step 3, image 1 of 1
    • 1)Remove the board out of the case
    • 2)Slowly pull out the scroll wheel out of the encoder wheel well
  4. How to fix jumpy scroll wheel of a computer mouse: step 4, image 1 of 1
    • Slowly remove the metallic clamps from the plastic body to free the plastic case, holding the rotating mechanism .(If possible remover the metallic case fully from underneath the board, if it is not soldered)
    • Pull back or bend the plastic case a little bit for easy insertion of spring
    • Place a small coil spring on the extreme end of the small metallic plate holding the rotating mechanism against the plastic body
    • Pull the other end of the coil and place it on the other end where the scroll wheel is inserted
    • This will ensure that the small metallic plate and rotating mechanism are not loose thereby not causing a jumpy scroll wheel
  5. How to fix jumpy scroll wheel of a computer mouse: step 5, image 1 of 1
    • Now put this entire contraption inside the metallic case and close the metallic clamps
    • Inserted the scroll wheel into the wheel well and close up the mouse
5 other people completed this guide.
Jithu Mohan
271 Reputation
1 Guide authored
3 Guide Comments
quel est la taille du resort qu'on doit acheter pour la réparation
chosela - Reply
Ottima guida come sempre! Complimenti
Paolo Galimberti - Reply
Excellent et si la souris est hors de cause penser à éteindre et rallumer le PC.
Jean-Marie Villez - Reply
Past 24 Hours: 26
Past 7 Days: 154
Past 30 Days: 756
All Time: 36,997
