You're viewing a previously published version of this guide.  View latest version
Older Newer
How to make Dyson AM07 (more) useable!
Frank
Frank and one other contributor
Last updated on August 11, 2024
2 - 5 minutes
Easy
Community-Contributed Guide
Introduction
Go to step 1
The remote control for the Dyson AM07 (and possibly other Dyson fans and heaters - I only own the AM07, so I don't know) has a sleek design, but unfortunately it's a case of "function follows form".
Without looking at it, you can't tell where the buttons are and what they do because they are flush with the rest of the thing. Which makes this remote not very useable, especially at night.
Luckily, there's a very easy (and reversible) fix for this. All you need is a glue gun! :)
iFixit earns commission when you buy through these links.
  1. How to make Dyson AM07 (more) useable!, Add some dots!: step 2, image 1 of 2 How to make Dyson AM07 (more) useable!, Add some dots!: step 2, image 2 of 2
    • Plug in your glue gun and let it heat up.
    • I made a big dot on the oscillation button, another one on the Standby ON/OFF button, and two more dots (big and small) on the Airflow control buttons. I don't use the Sleep Timer so I haven't added any dots to those two buttons.
    • If you don't get it right on the first try, don't worry. Just wait a couple of seconds for the glue to cool down and remove the dot. The glue comes off without leaving any residue or marks on the plastic.
  2. How to make Dyson AM07 (more) useable!, Bonus points: make shapes: step 3, image 1 of 2 How to make Dyson AM07 (more) useable!, Bonus points: make shapes: step 3, image 2 of 2
    • I used a carpet cutter (sharpest knife I had lying around) to cut the dot on the Standby ON/OFF button into an "I" shape for a little bit of different tactile feedback.
    • Some more ideas for customization: while the glue is still fluid, stick little parts of plastic, for example, in it to get different kind of buttons.
  3. How to make Dyson AM07 (more) useable!, The result: step 4, image 1 of 3 How to make Dyson AM07 (more) useable!, The result: step 4, image 2 of 3 How to make Dyson AM07 (more) useable!, The result: step 4, image 3 of 3
    • They could look better but the buttons are a lot more useable now, in my opinion.
Frank
85 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 39
All Time: 13,878
