How to open Logitech Z130 speakers
  1. How to open Logitech Z130 speakers, Getting prepared: step 1, image 1 of 1
    • Warning: Unplug the device from power before you start!
    • Unplug the audio cable as well
  2. How to open Logitech Z130 speakers, Remove the rear screws: step 2, image 1 of 1
    • At the rear of the speaker, remove two screws.
  3. How to open Logitech Z130 speakers, Remove the front screws: step 3, image 1 of 2 How to open Logitech Z130 speakers, Remove the front screws: step 3, image 2 of 2
    • Two front screws are hidden by the speaker grid
    • Simply by pulling it, remove the speaker grid
    • Remove the two screws which are now apparent
  4. How to open Logitech Z130 speakers, Remove the volume button and its nut: step 4, image 1 of 3 How to open Logitech Z130 speakers, Remove the volume button and its nut: step 4, image 2 of 3 How to open Logitech Z130 speakers, Remove the volume button and its nut: step 4, image 3 of 3
    • Remove the volume button by pulling it
    • Unscrew the nut which is now exposed
    • Remove the nut and the spacer
  5. How to open Logitech Z130 speakers, Remove the bottom screws: step 5, image 1 of 2 How to open Logitech Z130 speakers, Remove the bottom screws: step 5, image 2 of 2
    • Two front screws are hidden by a pad below the speaker.
    • Remove the pad
    • Remove the two bottom screws.
  6. How to open Logitech Z130 speakers, Open the speaker: step 6, image 1 of 1
    • Job's done, you are now able to open the speaker by gently pulling the front part of it.
4 other people completed this guide.
Benoit74
3,421 Reputation
11 Guides authored
3 Guide Comments
Thanks for this - I needed to open up my Z130 to spray contact cleaner in the volume potentiometer. No more breakup when turning the volume knob!
Jesse Smith - Reply
Whew! I was ruining the speaker plastic trying to pry this thing apart. Now I see I need to take out the two screws under the speaker grill!
Frank Zimmerman - Reply
Getting the speaker grill off was difficult - I had to insert a screwdriver and lever it upwards, bending the edge of the grill which later had to be straightened when I reassembled it.
Simon Kravis - Reply
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 89
All Time: 3,608
