How to open a bObsweep Robotic Vacuum for Repair
  1. How to open a bObsweep Robotic Vacuum for Repair, bObsweep's cover: step 1, image 1 of 3 How to open a bObsweep Robotic Vacuum for Repair, bObsweep's cover: step 1, image 2 of 3 How to open a bObsweep Robotic Vacuum for Repair, bObsweep's cover: step 1, image 3 of 3
    • Flip Bob over and remove the 7 screws around which hold the cover together.
    • Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
    • Depending on your model, there may be only 6 screws installed on bObsweep.
  2. How to open a bObsweep Robotic Vacuum for Repair: step 2, image 1 of 3 How to open a bObsweep Robotic Vacuum for Repair: step 2, image 2 of 3 How to open a bObsweep Robotic Vacuum for Repair: step 2, image 3 of 3
    • There are two screw holes inside the brush compartment: one in the centre, one on the left end. Remove both and keep aside for reassembly.
    • There are five more screws around bObsweep's edges. Two are installed at the top and bottom, and one on the right end of the main brush.
  3. How to open a bObsweep Robotic Vacuum for Repair: step 3, image 1 of 2 How to open a bObsweep Robotic Vacuum for Repair: step 3, image 2 of 2
    • Flip bOb back over so you can see the screen. Lift the cover up to reveal bObsweep’s main board.
    • Detach the power inlet from the cover. Grip and slide it out.
  4. How to open a bObsweep Robotic Vacuum for Repair: step 4, image 1 of 2 How to open a bObsweep Robotic Vacuum for Repair: step 4, image 2 of 2
    • Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
    • 1. On the bottom left corner: a small connector with red, black and white wires.
    • 2. One thick white wire that attaches on the right side of the previous connector.
    • 3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
    • Place the cover aside and begin your repair.
To reassemble your bObsweep, follow these instructions in reverse order.
Tatiana
737 Reputation
17 Guides authored
One Comment
Change battery, and still does what it did before. Battery life is one bar only, and the moment u push start it shuts right off. Even after charging all day. Please help
Gerqui Vila - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,761
