Introduction
This guide provides detailed instructions to disassemble your multimeter, allowing you to access internal components for maintenance or repair purposes.
Place the multimeter on its front.
Flip up the kickstand.
Tool used on this step:Phillips #1 Screwdriver$5.49
Use a PH1 screwdriver to unscrew the single screw holding the battery cover and kickstand.
Remove the battery cover and kickstand.
Remove the batteries, if present.
Use a PH1 screwdriver to unscrew the four screws holding the back cover.
Almost done!
