How to open the TicWatchPro
  1. How to open the TicWatchPro, Unfasten the screws: step 1, image 1 of 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the four 3.9 mm-long Torx T3 screws.
    • Depending on the condition of your driver, a Torx T4 bit may fit better.
    • Don't try to detach the back cover yet. It is still connected to the watch assembly.
  2. How to open the TicWatchPro, Open the watch: step 2, image 1 of 2 How to open the TicWatchPro, Open the watch: step 2, image 2 of 2
    • Be careful not to strain the sensor flex cable during this procedure.
    • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
  3. How to open the TicWatchPro, Disconnect the sensor cable: step 3, image 1 of 2 How to open the TicWatchPro, Disconnect the sensor cable: step 3, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
  4. How to open the TicWatchPro, Remove the back cover: step 4, image 1 of 1
    • Remove the back cover.
Repair didn’t go as planned? Check out our Answers community for help.
2 other people completed this guide.
Dominik Schnabelrauch
251,422 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,166 Guides authored
2 Guide Comments
T w lte 4G. Botón power como cambiar no conecta
yo tuve - Reply Share
Mostrar tutorial (si existe). gracias
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 2,058
