How to recover Chrome OS to its original factory state
  1. How to recover Chrome OS to its original factory state, How to recover Chrome OS to its original factory state: step 1, image 1 of 1
    • Backup any data on the hard drive since this will be wiped out when you decide to get a fresh Chrome OS.
  2. How to recover Chrome OS to its original factory state: step 2, image 1 of 1
    • Step 2: Once that's completed, you will need the use of 3 fingers: One to hold escape, one to hold the refresh button, and one to poke the power button.
    • If done correctly, your Chromebook will reset and have a screen that will tell you that you're in recovery mode.
    • From here, you can enter dev mode or restore to a new Chrome OS.
  3. How to recover Chrome OS to its original factory state: step 3, image 1 of 1
    • Install the Chromebook Recovery Utility Chrome App from the Chrome Web Store.
    • you need a SD card or thumb drive with 8 GB or more.
    • Make sure you select the correct Chromebook model! Selecting the wrong model will not work and you will have to restart the process!!
  4. How to recover Chrome OS to its original factory state: step 4, image 1 of 1
    • Step 4: Once you download the OS, put it on a fresh and wiped out USB or SD card and insert it in the Chromebook, but not the USB 3 ports.
    • Once the Chromebook has read the USB/SD card, this is the point of no return (for your hard drive at least)
  5. How to recover Chrome OS to its original factory state: step 5, image 1 of 1
    • Let the Chromebook do its thing.
    • Once it's done, you should go back to the original setup process and you are good to go!
35 other people completed this guide.
JAShadic
1,041 Reputation
1 Guide authored
Apple fan boys Member of Apple fan boys
Community
51 Members
45 Guides authored
9 Comments
what can be the problem if there is an error message? freakin ukranian took my laptop away didnt know what he was doing charged me 2000rubles just for the nerves and travelling an hour to him to collect the computer with the same $@$*. i followed all the troubleshoots on the chrome os recovery site. is it idiotic to get a new mother straight away?
dematisch - Reply
it deosn't work at all
Liam Nye - Reply
Same here....
jimstha126 -
I did everything the internet says to do to fix this on my Chromebook and it still says the same thing and hasn't changed. But I noticed that if I click ctrl+alt+ shift+R it will change the tab recovery_reason to 0×05 TPM error in read-only firmware and then if I click ESC+ refresh+power button, the tab recovery reason goes back to 0×02 recovery button pressed. So I'm very confused. The screen when I turn it on is a white background that has a giant yellow exclamation mark with words under it saying Chrome OS is missing or damaged. Please insert a recovery USB stick or SD card. (note: the blue USB port will NOT work for recovery) I brought it to the store I bought it from but they literally didn't care or help me in anyway and they sent me away
Tiffanie Smith - Reply
same problem. Did you find a way to fix this?
Kelli Frederick -
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 58
All Time: 99,721
