Introduction
Do you have a pair of WESC Maraca Headphones with worn ear cushions? Use this guide to repair them and avoid ruining the bare cushions or completely replacing the headphones.
Remove the cushion from the headphones by carefully pushing the edges out from the sides of the ear piece.
Use a marker to draw an arrow shape around the bottom of the cushion.
The arrow's point should fall toward the center of the cushion.
The points on the sides of the arrow should extend well beyond the edge of the cushion. They should not be aligned with the corners of the cushion.
The bottom of the arrow should line up with the sides and bottom of the cushion.
Repeat this step to draw a wider arrow for the side of the cushion.
Once you have all of the fabric attached, stretch the edges of the cushion back over the headphone's ear piece.
Use a thin plastic card to carefully tuck the edges of the cushion back into the ear piece.
Your headphones are now reupholstered and ready to use again.
5 other people completed this guide.
