How to remove Bing redirect malware from Mac
  1. How to remove Bing redirect malware from Mac, Terminate the malicious process: step 1, image 1 of 1
    • Click the Go button in your Mac’s Finder bar, select Utilities in the pull-down list, and open the Activity Monitor.
    • Try to spot the malicious process. Focus on executables that spawn multiple threads, have icons you don’t recognize and use up a significant amount of CPU and memory.
    • If you find the rogue process, click the X button in the upper right-hand part of the Activity Monitor app and then select the Quit or Force Quit option on the follow-up dialog.
  2. How to remove Bing redirect malware from Mac, Uninstall the unwanted app: step 2, image 1 of 1
    • Expand the Go menu in the Finder area again and select Applications. Check the list for an app that has recently cropped up on your Mac without your permission. Move the culprit to the Trash.
  3. How to remove Bing redirect malware from Mac, Remove malicious LaunchAgents and LaunchDaemons: step 3, image 1 of 2 How to remove Bing redirect malware from Mac, Remove malicious LaunchAgents and LaunchDaemons: step 3, image 2 of 2
    • Select the Go to Folder option as shown below.
    • Enter ~/Library/LaunchAgents (with the tilde sign) and click Go.
    • Check the LaunchAgents path for recently added dubious files and remove them.
    • Use the Go to Folder function to open the following paths: /Library/LaunchAgents (without the tilde sign), /Library/LaunchDaemons, and ~/Library/Application Support. Go over their contents and move suspicious files and folders to the Trash.
  4. How to remove Bing redirect malware from Mac, Eliminate dodgy Login Items: step 4, image 1 of 1
    • Head to System Preferences, select Users & Groups, and click the Login Items tab. To make changes, you will need to click the padlock icon at the bottom left and type your password. Then, select the malicious app and click the “minus” sign to eliminate it from the list.
  5. How to remove Bing redirect malware from Mac, Remove the rogue configuration profile: step 5, image 1 of 1
    • Go to System Preferences and select Profiles. Note that this feature will be missing if there are no device profiles installed on your Mac. If it’s listed, though, open it, select the unwanted profile, and click the “minus” sign to get rid of it.
  6. How to remove Bing redirect malware from Mac, Empty the Trash: step 6, image 1 of 1
    • Control-click the Trash icon in your Mac’s Dock, select Empty Trash in the contextual menu, and click the Empty Trash button on the follow-up dialog to confirm this action.
  7. How to remove Bing redirect malware from Mac, Clear redundant data in Safari: step 7, image 1 of 3 How to remove Bing redirect malware from Mac, Clear redundant data in Safari: step 7, image 2 of 3 How to remove Bing redirect malware from Mac, Clear redundant data in Safari: step 7, image 3 of 3
    • Open the web browser, expand the Safari pull-down menu in the Finder bar, and select Preferences. Click the Advanced tab and put a checkmark next to the option that says Show Develop menu in menu bar (if it’s not enabled already).
    • Now that the Develop menu is displayed in the Finder area, click it and select Empty Caches as illustrated below.
    • Expand the History menu and select Clear History. Click the Clear History button on the confirmation dialog.
    • Reopen the Safari Preferences screen, click the Privacy tab, and select Manage Website Data. Click the Remove All button to delete all the bits and pieces of information websites have stored to track your online activities. Then, click the Done button.
    • Restart Safari.
  8. How to remove Bing redirect malware from Mac, Reset Google Chrome (if affected): step 8, image 1 of 1
    • Open Chrome, click the Customize and control Google Chrome button, and select Settings.
    • Click the Advanced button in the sidebar and scroll down to Reset settings. Select the Restore settings to their original defaults option and click Reset settings.
    • Restart Chrome.
  9. How to remove Bing redirect malware from Mac, Reset Mozilla Firefox (if affected): step 9, image 1 of 1
    • Open Firefox, click the Open menu button, go to Help, and select Troubleshooting Information.
    • Click the Refresh Firefox button and confirm the action once a follow-up dialog pops up.
    • Restart Firefox.
To avoid the Bing redirect malware down the road, treat app installers with caution – especially ones downloaded from unofficial software marketplaces. This infection mostly hinges on app bundles to spread. The default (“express”) installation option only mentions the benign software and never reveals the real structure of such packages. As a result, users click through without a second thought, only to discover shortly that their web browsers are taken over.
4 other people completed this guide.
David Balaban
721 Reputation
2 Guides authored
One Comment
I have had this issue on a computer (Mac, all browsers) for a little while, where google searches would redirect to bing, and tried everything. I thought to check the /etc/hosts file, and that's where the problem was. So, if above tips do not work, that is another place to check.
- From terminal: sudo vim /etc/hosts (then type in password)
- Check for any lines that are pointing google.com to an IP address, or otherwise manipulating google.com
- Comment out these lines with a # (or delete them)
- Save
- Flush your DNS cache
This solved my issue, hopefully this can help someone else too.
VAR - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 21
All Time: 20,134
