How to replace the door knob
  1. How to replace the door knob, Remove the screw holding the handle: step 1, image 1 of 1
    • It is advisable to work with two people, one holding the outer handle on the outside and the other unloading the screw on the other side.
    • Remove the two screws.
  2. How to replace the door knob, Remove the handle: step 2, image 1 of 1
    • Use pry bar carefully pry around, you can remove both sides of the door handle.
    • There is usually a plastic washer between the handle and the door, taking care not to damage it.
    • There will be a metal square shaft connected between the handle. Be careful not to lose it when removing the inside handle because the shaft is inside and outside.
  3. How to replace the door knob, Pay attention to the square shaft: step 3, image 1 of 1
    • Pay attention to the installation direction of this square shaft. Do not knock it off when removing the handle.
Reversing the steps to know hot to install the know. It's easier than your thought , isn't it?
5 other people completed this guide.
Special thanks to these translators:
zh en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Z.Heng
3,802 Reputation
3 Guides authored
1 Guide Comment
图文并茂,生动形象,谢谢你的分享!
Conti - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 36
All Time: 1,957
