How to test an RCA cable
  1. How to test an RCA cable, The Multimeter: step 1, image 1 of 2 How to test an RCA cable, The Multimeter: step 1, image 2 of 2
    • Take a multimeter placed on the setting for the insulation and continuity tests then press "select" to set it in Ohm meter
    • The black banana-type cable and plugged it into the COM port
    • the red banana cable will be placed on the resistance measurement port as in photo number 1
  2. How to test an RCA cable, continuity test.: step 2, image 1 of 1
    • Perform an insulation test between the tip and the sleeve of the cable to do this, position the red cable on the sleeve and the black cable on the tip. The device should normally display OL or "---". If a value is displayed, your cable has a fault. Do this step on all cable end caps
  3. How to test an RCA cable, RCA Cable Test (Black): step 3, image 1 of 2 How to test an RCA cable, RCA Cable Test (Black): step 3, image 2 of 2
    • In order to perform the test, now place the ends of the banana cables on the tip plug of the RCA cable. At this time you will see 03.0 Ohm appear on your Ohm meter but you will also hear a beep (photo 1)
    • Puis ensuite placer les embouts des câbles banane sur le sleeve du câble RCA, si vous observez la mention OL cela indique que l'appareil mesure une résistance trop haute et donc que le câble est sectionné. Si vous obtenez un BIP ou un résultat autre que OL ou "---" votre câble est en bonne état. Vous pouvez donc passer a l'étape suivante.
  4. How to test an RCA cable, RCA Cable Test (Red): step 4, image 1 of 2 How to test an RCA cable, RCA Cable Test (Red): step 4, image 2 of 2
    • do the same steps on the other end of the cable.
Well done you made it
(Do not hesitate if you liked, gave 30 points;) )
3 other people completed this guide.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Léo Léo
580 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 115
All Time: 8,484
