How to tighten the Razor A handlebar clamp
  1. How to tighten the Razor A handlebar clamp, How to tighten the Razor A handlebar clamp: step 1, image 1 of 1
    • Locate the T-tube clamp. It is in the middle of the steering column.
  2. How to tighten the Razor A handlebar clamp: step 2, image 1 of 2 How to tighten the Razor A handlebar clamp: step 2, image 2 of 2
    • Open the clamp by pulling the lever away from the scooter.
  3. How to tighten the Razor A handlebar clamp: step 3, image 1 of 2 How to tighten the Razor A handlebar clamp: step 3, image 2 of 2
    • Locate the screw on the side of clamp.
    • Turn the screw on the side of the clamp by hand in a clockwise direction.
    • Attempt to close the clamp. If the lever is too tight to close, loosen the screw slightly and try again.
    • The T-tube should now be locked in place. If it continues to fall down, repeat the instructions in this guide.
Finish Line
Jordyn
544 Reputation
5 Guides authored
Cal Poly, Team 9-13, Amido Fall 2012 Member of Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 3,779
