Hp 15-f305dx Keyboard Replacement
  1. Hp 15-f305dx Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Hp 15-f305dx Keyboard Replacement: step 2, image 1 of 1
    • Turn the computer upside down on a flat surface.
  3. Hp 15-f305dx Keyboard Replacement: step 3, image 1 of 3 Hp 15-f305dx Keyboard Replacement: step 3, image 2 of 3 Hp 15-f305dx Keyboard Replacement: step 3, image 3 of 3
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Hp 15-f305dx Keyboard Replacement: step 4, image 1 of 2 Hp 15-f305dx Keyboard Replacement: step 4, image 2 of 2
    • Lift the battery from the middle and then pivot it outward to remove it from the computer.
  5. Hp 15-f305dx Keyboard Replacement, Keyboard: step 5, image 1 of 1
    • Flip the laptop around.
  6. Hp 15-f305dx Keyboard Replacement: step 6, image 1 of 2 Hp 15-f305dx Keyboard Replacement: step 6, image 2 of 2
    • Remove the single 7 mm screw from the top middle of the laptop using a Phillips #0 screwdriver.
  7. Hp 15-f305dx Keyboard Replacement: step 7, image 1 of 2 Hp 15-f305dx Keyboard Replacement: step 7, image 2 of 2
    • Pry the keyboard out of the laptop gently and flip the keyboard around.
  8. Hp 15-f305dx Keyboard Replacement: step 8, image 1 of 1
    • Disconnect the connected cable from the mainboard.
Brandon
681 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 653
