Hp Mini 2133 Hard Disk Replacement
  1. Hp Mini 2133 Hard Disk Replacement, Battery: step 1, image 1 of 3 Hp Mini 2133 Hard Disk Replacement, Battery: step 1, image 2 of 3 Hp Mini 2133 Hard Disk Replacement, Battery: step 1, image 3 of 3
    • First power off the device.
    • And remove the battery.
  2. Hp Mini 2133 Hard Disk Replacement, Remove the keyboard: step 2, image 1 of 2 Hp Mini 2133 Hard Disk Replacement, Remove the keyboard: step 2, image 2 of 2
    • Remove the screws
    • And open it up
    • Then disconect the cable for the key board.
  3. Hp Mini 2133 Hard Disk Replacement, Cable for the keyboard: step 3, image 1 of 3 Hp Mini 2133 Hard Disk Replacement, Cable for the keyboard: step 3, image 2 of 3 Hp Mini 2133 Hard Disk Replacement, Cable for the keyboard: step 3, image 3 of 3
    • Now disconect the cable under the keyboard.
    • ATTENTION There is a lever to disconect the keyboard.
  4. Hp Mini 2133 Hard Disk Replacement, Disconect the Disk: step 4, image 1 of 2 Hp Mini 2133 Hard Disk Replacement, Disconect the Disk: step 4, image 2 of 2
    • Now you throw from the plastic.
  5. Hp Mini 2133 Hard Disk Replacement, Remove the protector: step 5, image 1 of 1
    • Now remove the protector.
    • The black screw does not come off completely.
  6. Hp Mini 2133 Hard Disk Replacement, Remove the disk: step 6, image 1 of 2 Hp Mini 2133 Hard Disk Replacement, Remove the disk: step 6, image 2 of 2
    • Now remove the disk.
    • CAUTION WITH THE CONECTOR!
  7. Hp Mini 2133 Hard Disk Replacement, Remove the conector from the disk: step 7, image 1 of 2 Hp Mini 2133 Hard Disk Replacement, Remove the conector from the disk: step 7, image 2 of 2
    • Now you remove the conector from the disk.
Para reensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
Guzmini
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 120
