Hp Pavilion dv6-2155dx Optical Drive Replacement
  1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: step 1, image 1 of 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: step 1, image 2 of 2
    • Flip the computer around to the back side.
    • Remove the three screws from the memory module cover.
    • Screws will not come out all the way.
    • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
  2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: step 2, image 1 of 1
    • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
    • The screw is 7mm long and head is 4mm wide.
  3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: step 3, image 1 of 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: step 3, image 2 of 2
    • Locate the small hole next to the eject button.
    • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
    • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
  4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: step 4, image 1 of 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: step 4, image 2 of 2
    • Gently pull the Optical drive out of the slot until the whole thing comes out.
2 other people completed this guide.
Joseph Sanda
522 Reputation
4 Guides authored
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G2
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 832
