Hp Zbook studio g3 RAM Replacement
  1. Hp Zbook studio g3  RAM Replacement, Removing the dust filter: step 1, image 1 of 1
    • Remove the 4 screws holding down the dust filter
    • Remove the dust filter
  2. Hp Zbook studio g3  RAM Replacement, Removing the housing: step 2, image 1 of 1
    • Remove the 4 outer screws.
    • Remove the 2 inner screws holding the housing down.
    • Now lift the housing. This may require some force
  3. Hp Zbook studio g3  RAM Replacement, Removing the old Ram module: step 3, image 1 of 2 Hp Zbook studio g3  RAM Replacement, Removing the old Ram module: step 3, image 2 of 2
    • Remove the old ram module by pushing these two tabs outwards. The module should swing up
    • Now pull the module out away from the holder
    • Note: The removal of the module should not require a lot of force
  4. Hp Zbook studio g3  RAM Replacement, Installing the new memory: step 4, image 1 of 1
    • Orient the memory modules such that then notch in the connector lines up with the grove in the module
    • slide the module all the way into the holder such that the pins are in the connector
    • Push down on the module to lock it in the holders
    • Note: Make sure the module is in straight
3 other people completed this guide.
jort
166 Reputation
1 Guide authored
3 Guide Comments
Would be really good to have one for the SSD
Andrew Hansford - Reply
I am thinking of expanding the storage on this model. If I get around to it I’ll post a guide
jort -
For retail stores like me this is very helpful. I can send to customers so they can upgrade themselves. Thanks for sharing
My Website: Laptop Workstation cũ Tphcm
Laptop Titan - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 35
All Time: 4,680
