Huawei Ascend G700 SD Card Replacement
  1. Huawei Ascend G700 SD Card Replacement, Preparation: step 1, image 1 of 2 Huawei Ascend G700 SD Card Replacement, Preparation: step 1, image 2 of 2
    • Disconnect all connected devices (such as headphones and USB chargers).
    • Turn the device off.
    • Turn the device around.
  2. Huawei Ascend G700 SD Card Replacement: step 2, image 1 of 1
    • On the same side as the powerbutton is a little notch. Using it you will have to carefully remove the back cover.
    • Use a small prying tool if you can't do this with your fingers.
  3. Huawei Ascend G700 SD Card Replacement: step 3, image 1 of 2 Huawei Ascend G700 SD Card Replacement: step 3, image 2 of 2
    • Now you can remove the battery, that has to be pryed off in the marked location.
  4. Huawei Ascend G700 SD Card Replacement, SD Card: step 4, image 1 of 3 Huawei Ascend G700 SD Card Replacement, SD Card: step 4, image 2 of 3 Huawei Ascend G700 SD Card Replacement, SD Card: step 4, image 3 of 3
    • You can now pull the SD card downwards.
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
Alex Niculescu is helping us fix the world! Want to contribute?
Start translating ›
Leonard Kesting
1,229 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 455
