Huawei Ascend P6-U06 Back Panel Replacement
  1. Huawei Ascend P6-U06 Back Panel Replacement, Back Panel: step 1, image 1 of 2 Huawei Ascend P6-U06 Back Panel Replacement, Back Panel: step 1, image 2 of 2
    • Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
    • You may need a sharp thin object to get underneath the plastic.
  2. Huawei Ascend P6-U06 Back Panel Replacement: step 2, image 1 of 2 Huawei Ascend P6-U06 Back Panel Replacement: step 2, image 2 of 2
    • Rotate the phone 180 degrees so that the bottom of the phone is now facing up.
    • Firmly push up on the back panel with your thumbs.
    • Lift up the back panel from the top right corner and gently pull it away from the phone.
13 other people completed this guide.
Alison Jones
391 Reputation
1 Guide authored
Cal Poly, Team 4-44, Amido Fall 2014 Member of Cal Poly, Team 4-44, Amido Fall 2014
CPSU-AMIDO-F14S4G44
5 Members
11 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 31
All Time: 5,372
