Huawei Ascend W1 Speaker Replacement
  1. Huawei Ascend W1 Speaker Replacement, The phone's orientation.: step 1, image 1 of 1
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Huawei Ascend W1 Speaker Replacement, Removing the back cover.: step 2, image 1 of 1
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Huawei Ascend W1 Speaker Replacement: step 3, image 1 of 1
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. Huawei Ascend W1 Speaker Replacement, Removing the battery.: step 4, image 1 of 3 Huawei Ascend W1 Speaker Replacement, Removing the battery.: step 4, image 2 of 3 Huawei Ascend W1 Speaker Replacement, Removing the battery.: step 4, image 3 of 3
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  5. Huawei Ascend W1 Speaker Replacement, Remove all the screws: step 5, image 1 of 2 Huawei Ascend W1 Speaker Replacement, Remove all the screws: step 5, image 2 of 2
    • After removing the battery, you will need to remove the screws holding the phone's middle cover.
    • There are eleven screws that hold the plate to the rest of the phone.
    • The screw that is marked by the orange circle is covered by a white dot. It is used as a tampering deterrent.
  6. Huawei Ascend W1 Speaker Replacement, Removing the lower circuit plate: step 6, image 1 of 2 Huawei Ascend W1 Speaker Replacement, Removing the lower circuit plate: step 6, image 2 of 2
    • After all the screws are removed from the back circuit, use your fingers to remove the lower section of the middle cover.
    • Grab the top of the lower middle cover and pull it outward towards you, exposing the circuit board underneath.
  7. Huawei Ascend W1 Speaker Replacement, Removing the rest of the middle cover.: step 7, image 1 of 2 Huawei Ascend W1 Speaker Replacement, Removing the rest of the middle cover.: step 7, image 2 of 2
    • Begin working your way around the sides of the middle cover, unsnapping it gently.
    • Be gentle as you pry the middle cover off. The parts may break if you are too forceful.
  8. Huawei Ascend W1 Speaker Replacement, Removing the speaker: step 8, image 1 of 3 Huawei Ascend W1 Speaker Replacement, Removing the speaker: step 8, image 2 of 3 Huawei Ascend W1 Speaker Replacement, Removing the speaker: step 8, image 3 of 3
    • The speaker is attached to the inside of the back cover and visible once the middle cover is removed.
    • Using small pliers, gently remove the speaker.
    • The speaker may be difficult to remove due to the adhesive that keeps it in place.
2 other people completed this guide.
Jaie Hillery
1,718 Reputation
10 Guides authored
USF Tampa, Team 16-6, Blackwell Winter 2016 Member of USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Members
22 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 699
