Huawei Ascend XT Battery Replacement
  1. Huawei Ascend XT Battery Replacement, Battery: step 1, image 1 of 2 Huawei Ascend XT Battery Replacement, Battery: step 1, image 2 of 2
    • Use the 0.8 Sim driver bit to remove the SIM tray by inserting it into the hole on the side of the device.
    • Once the hole is pressed in firm, the SIM tray will pop out. This allows you to grab it, and extract it from the device.
  2. Huawei Ascend XT Battery Replacement: step 2, image 1 of 2 Huawei Ascend XT Battery Replacement: step 2, image 2 of 2
    • Make a thumbs-up and use it to grip the plastic opening tool with the flat end pointing in the direction of your thumb.
    • Place the flat end of the opening tool slightly inside the charging port and place your thumb on the back of the phone.
    • Press into the phone with your thumb while pulling the opening tool back with your fist to begin prying the back off.
  3. Huawei Ascend XT Battery Replacement: step 3, image 1 of 2 Huawei Ascend XT Battery Replacement: step 3, image 2 of 2
    • Slide the flat end of the spudger along the edge of the device, prying off the back cover.
    • Carefully remove the back cover. This may be difficult due to glue on the inside.
  4. Huawei Ascend XT Battery Replacement: step 4, image 1 of 2 Huawei Ascend XT Battery Replacement: step 4, image 2 of 2
    • Use a Phillips screwdriver to remove 20 screws around the perimeter of the phone.
  5. Huawei Ascend XT Battery Replacement: step 5, image 1 of 3 Huawei Ascend XT Battery Replacement: step 5, image 2 of 3 Huawei Ascend XT Battery Replacement: step 5, image 3 of 3
    • First, carefully remove the speaker assembly at the bottom of the phone.
    • Use a spudger to pry up the antenna assembly located along the top right-hand side of the phone.
    • Use a spudger to pull off the top-left tab.
    • Finally, carefully remove the entire back plate assembly from the motherboard.
  6. Huawei Ascend XT Battery Replacement: step 6, image 1 of 1
    • Place the tip of your spudger or opening too under the edge of the connector, and pry the battery connector straight up from its socket.
  7. Huawei Ascend XT Battery Replacement: step 7, image 1 of 2 Huawei Ascend XT Battery Replacement: step 7, image 2 of 2
    • Use the spudger to pry the lithium battery away from battery compartment.
    • Insert new battery and connect.
5 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 4,545
