Huawei Honor 6x Front Display Panel Replacement
Tessa Kemper
Tessa Kemper and 6 other contributors
Last updated on May 7, 2024
30 minutes - 1 hour
Moderate
Introduction
Go to step 1
If your screen becomes cracked or is inoperable, the front display panel will need to be replaced. This process involves removing nearly every component of the phone before gaining access to the front display panel.
Tools
Show more…
  1. Huawei Honor 6x Front Display Panel Replacement, SIM Card: step 1, image 1 of 1
    • Turn off the device.
  2. Huawei Honor 6x Front Display Panel Replacement: step 2, image 1 of 2 Huawei Honor 6x Front Display Panel Replacement: step 2, image 2 of 2
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Huawei Honor 6x Front Display Panel Replacement: step 3, image 1 of 1
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Huawei Honor 6x Front Display Panel Replacement: step 4, image 1 of 1
    • Remove the SIM card from the compartment using two fingers.
  5. Huawei Honor 6x Front Display Panel Replacement, Back Cover: step 5, image 1 of 2 Huawei Honor 6x Front Display Panel Replacement, Back Cover: step 5, image 2 of 2
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
  6. Huawei Honor 6x Front Display Panel Replacement: step 6, image 1 of 3 Huawei Honor 6x Front Display Panel Replacement: step 6, image 2 of 3 Huawei Honor 6x Front Display Panel Replacement: step 6, image 3 of 3
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
  7. Huawei Honor 6x Front Display Panel Replacement: step 7, image 1 of 2 Huawei Honor 6x Front Display Panel Replacement: step 7, image 2 of 2
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
  8. Huawei Honor 6x Front Display Panel Replacement: step 8, image 1 of 3 Huawei Honor 6x Front Display Panel Replacement: step 8, image 2 of 3 Huawei Honor 6x Front Display Panel Replacement: step 8, image 3 of 3
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
  9. Huawei Honor 6x Front Display Panel Replacement: step 9, image 1 of 1
    • Remove the motherboard cover from the device using a spudger or your fingers.
  10. Huawei Honor 6x Front Display Panel Replacement, Battery: step 10, image 1 of 2 Huawei Honor 6x Front Display Panel Replacement, Battery: step 10, image 2 of 2
    • Remove the four connectors by placing the spudger between the motherboard and the connectors.
    • Press upwards against the connectors until they disconnect.
    • The connectors will make a "click" sound when disconnected.
  11. Huawei Honor 6x Front Display Panel Replacement: step 11, image 1 of 2 Huawei Honor 6x Front Display Panel Replacement: step 11, image 2 of 2
    • Remove the battery by first prying a spudger between the battery and the screen.
    • Slice through the adhesive by pushing card around and underneath the battery.
    • The adhesive is fairly strong, so make sure to press firmly against the adhesive.
    • Do not excessively bend the battery. Bending the battery too much can cause it to break and even catch fire.
  12. Huawei Honor 6x Front Display Panel Replacement: step 12, image 1 of 2 Huawei Honor 6x Front Display Panel Replacement: step 12, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    • Using the plastic card, remove the battery by lifting it from the casing.
  13. Huawei Honor 6x Front Display Panel Replacement, Front Display Panel: step 13, image 1 of 2 Huawei Honor 6x Front Display Panel Replacement, Front Display Panel: step 13, image 2 of 2
    • Remove the last two connectors from the motherboard using a spudger or your fingers.
    • All cables should now be detached from the motherboard.
  14. Huawei Honor 6x Front Display Panel Replacement: step 14, image 1 of 3 Huawei Honor 6x Front Display Panel Replacement: step 14, image 2 of 3 Huawei Honor 6x Front Display Panel Replacement: step 14, image 3 of 3
    • Remove the four 2mm Phillips #00 screws.
  15. Huawei Honor 6x Front Display Panel Replacement: step 15, image 1 of 2 Huawei Honor 6x Front Display Panel Replacement: step 15, image 2 of 2
    • Gently lift the motherboard from the phone using two fingers or a spudger.
  16. Huawei Honor 6x Front Display Panel Replacement: step 16, image 1 of 1
    • Remove the speaker using the tip of a spudger.
    • The speaker may need to be re-glued during reassembly.
  17. Huawei Honor 6x Front Display Panel Replacement: step 17, image 1 of 3 Huawei Honor 6x Front Display Panel Replacement: step 17, image 2 of 3 Huawei Honor 6x Front Display Panel Replacement: step 17, image 3 of 3
    • Remove the five 2mm Phillips #00 screws using a screwdriver.
    • Remove the two 2mm #5 Torx screws using a screwdriver.
  18. Huawei Honor 6x Front Display Panel Replacement: step 18, image 1 of 2 Huawei Honor 6x Front Display Panel Replacement: step 18, image 2 of 2
    • Remove the metal plate from the vibrator assembly using a spudger.
  19. Huawei Honor 6x Front Display Panel Replacement: step 19, image 1 of 3 Huawei Honor 6x Front Display Panel Replacement: step 19, image 2 of 3 Huawei Honor 6x Front Display Panel Replacement: step 19, image 3 of 3
    • Snap the two connectors off using a spudger or your finger.
  20. Huawei Honor 6x Front Display Panel Replacement: step 20, image 1 of 1
    • Pry the micro USB port off of the phone using a spudger.
  21. Huawei Honor 6x Front Display Panel Replacement: step 21, image 1 of 3 Huawei Honor 6x Front Display Panel Replacement: step 21, image 2 of 3 Huawei Honor 6x Front Display Panel Replacement: step 21, image 3 of 3
    • Pry the speaker and microphone assembly off of the phone by sliding a spudger down along the bottom.
  22. Huawei Honor 6x Front Display Panel Replacement: step 22, image 1 of 2 Huawei Honor 6x Front Display Panel Replacement: step 22, image 2 of 2
    • Pull the volume buttons off using tweezers or the end of a spudger.
    • It may take a bit of wiggling and poking to get through the adhesive.
12 other people completed this guide.
Tessa Kemper
591 Reputation
3 Guides authored
Cal Poly, Team S13-G5, White Fall 2018 Member of Cal Poly, Team S13-G5, White Fall 2018
CPSU-WHITE-F18S13G5
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 28
All Time: 5,068
