Huawei Honor 8 Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Huawei Honor 8 Battery Replacement, Rear Glass & Frame: step 1, image 1 of 1
    • Make sure you spend at least 5 minutes heating up the adhesive. Prying off the glass cover too early can result in cracking the panel.
    • Using a heat gun or hairdryer, apply heat approximately three inches above the glass panel to warm up the adhesive around the outside edge of the phone.
    • Make sure to apply heat evenly across the outside edge of the device.
  2. Huawei Honor 8 Battery Replacement: step 2, image 1 of 2 Huawei Honor 8 Battery Replacement: step 2, image 2 of 2
    • Be careful not to tear the orange ribbon wire when removing the back panel.
    • Using a plastic opening tool, gently pry up a corner of the rear glass panel.
    • Slowly slide the plastic opening tool around the outside of the glass panel to break through the adhesive.
    • Additional plastic opening tools can be used to help separate the back panel from the phone body.
    • Gently lift the back panel off once all the adhesive has been removed.
  3. Huawei Honor 8 Battery Replacement: step 3, image 1 of 3 Huawei Honor 8 Battery Replacement: step 3, image 2 of 3 Huawei Honor 8 Battery Replacement: step 3, image 3 of 3
    • Using a Phillips PH00 screwdriver, remove the silver Phillips 3.5 mm screw circled in red.
    • Using a spudger, gently lift off the small metal tab that was held in place by the screw.
    • Gently pry off the orange ribbon wire on the back panel.
  4. Huawei Honor 8 Battery Replacement: step 4, image 1 of 1
    • Keep the tiny screws on a magnetic pad or a designated area so they will not be lost. There are eighteen screws in total.
    • Using a Phillips PH00 screwdriver, remove the eight silver Phillips 3.5 mm screws circled in red.
    • Using a Phillips PH00 screwdriver, remove the six black Phillips 4.0 mm screws circled in orange.
    • Using a Phillips PH00 screwdriver, remove the single silver 3.0 mm Phillips screw circled in yellow.
    • Using the Phillips PH00 screwdriver tip, gently scratch away the white stickers outlined in green circles to expose hidden screws.
    • Using a Phillips PH00 screwdriver, remove the two black Phillips 4.0 mm screws circled in green.
  5. Huawei Honor 8 Battery Replacement: step 5, image 1 of 3 Huawei Honor 8 Battery Replacement: step 5, image 2 of 3 Huawei Honor 8 Battery Replacement: step 5, image 3 of 3
    • Slowly slide the plastic opening tool around the perimeter of the inner lining.
    • Additional plastic opening tools can be used to help separate the inner lining from the phone body.
    • Gently pull the inner lining up to remove it from the phone body.
  6. Huawei Honor 8 Battery Replacement, Motherboard: step 6, image 1 of 3 Huawei Honor 8 Battery Replacement, Motherboard: step 6, image 2 of 3 Huawei Honor 8 Battery Replacement, Motherboard: step 6, image 3 of 3
    • Holding the phone so that the cameras are at the top, locate the small hole on the top right edge of the device.
    • Using the 0.8 mm Sim Eject tool, push down on the small hole to release the Sim Card tray.
    • Gently pull out the Sim Card tray and set it aside.
  7. Huawei Honor 8 Battery Replacement: step 7, image 1 of 1
    • In the following steps you will disconnect the five connectors circled in red holding the motherboard in place.
  8. Huawei Honor 8 Battery Replacement: step 8, image 1 of 2 Huawei Honor 8 Battery Replacement: step 8, image 2 of 2
    • Gently pull the small ribbon connection between the battery and motherboard upward to disconnect it.
    • Use a spudger to help pry off the connection if necessary.
  9. Huawei Honor 8 Battery Replacement: step 9, image 1 of 1
    • Use a spudger to gently pry off the small antenna cable on the right side of the motherboard.
  10. Huawei Honor 8 Battery Replacement: step 10, image 1 of 2 Huawei Honor 8 Battery Replacement: step 10, image 2 of 2
    • Using a spudger, gently pry up the small connection that holds the motherboard in place.
  11. Huawei Honor 8 Battery Replacement: step 11, image 1 of 1
    • Using a spudger, gently pry up the connector near the left edge of the motherboard.
  12. Huawei Honor 8 Battery Replacement: step 12, image 1 of 1
    • Use a spudger to gently pry off the small connection on the far left edge of the motherboard.
  13. Huawei Honor 8 Battery Replacement: step 13, image 1 of 2 Huawei Honor 8 Battery Replacement: step 13, image 2 of 2
    • Use a spudger to pry up a corner of the motherboard.
    • Lift the motherboard to remove it from the body of the phone.
  14. Huawei Honor 8 Battery Replacement, Battery: step 14, image 1 of 2 Huawei Honor 8 Battery Replacement, Battery: step 14, image 2 of 2
    • Using a spudger, pry off the small connection between the speaker and phone body located near the bottom of the device circled in red.
    • Gently pry up a corner of the speaker using a spudger.
    • Lift the speaker up and out of the phone body.
  15. Huawei Honor 8 Battery Replacement: step 15, image 1 of 2 Huawei Honor 8 Battery Replacement: step 15, image 2 of 2
    • Avoid using a heat gun for this step as overheating the battery can cause permanent damage.
    • You may use an iOpener on the front side of the phone to safely heat and loosen the adhesive under the battery.
    • Insert the plastic spudger into the gap between the frame and the battery.
    • Move the spudger around the outside edge of the battery to remove the adhesive.
    • Do not bend or puncture the battery. There is a lot of adhesive holding the battery in place, moving the spudger may require some effort. Use the plastic opening tools to help pry each side open.
  16. Huawei Honor 8 Battery Replacement: step 16, image 1 of 3 Huawei Honor 8 Battery Replacement: step 16, image 2 of 3 Huawei Honor 8 Battery Replacement: step 16, image 3 of 3
    • Once all the adhesive has been removed from the battery, use the spudger and plastic opening tools to gently pry the battery away from the frame.
42 other people completed this guide.
Kevin Shu
239 Reputation
1 Guide authored
Cal Poly, Team S18-G2, Forte Fall 2017 Member of Cal Poly, Team S18-G2, Forte Fall 2017
CPSU-FORTE-F17S18G2
4 Members
24 Guides authored
24 Comments
Where are the battery installation and reassembly instructions?
Nate Gardner - Reply
Just go back in reverse order, Einstein
cherry blossom -
I replaced the battery on my Huawei Honor 8 and after power up it doesn’t see the SIM card. There’s no way to install the sim card tray backwards or put the SIM card in wrong. Any ideas?
gaildagan - Reply
Never mind. I figured it out. The metal SIM card cage got distorted and the tray was sliding in behind it, not into it. I gently bent the cage back into shape and all is well.
gaildagan -
Do I need to apply new adhesive ? or re-use what is already on the device?
Qing Li - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 40,947
