Huawei Honor 8 Screen Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Huawei Honor 8 Screen Replacement, Remove the back casing: step 1, image 1 of 3 Huawei Honor 8 Screen Replacement, Remove the back casing: step 1, image 2 of 3 Huawei Honor 8 Screen Replacement, Remove the back casing: step 1, image 3 of 3
    • Heat the parts marked in red on the back side of the phone with a hair dryer or heat gun.
    • Attention: The sides have to be hot, not scalding.
    • Insert the iSesamo delicatley between the two sides (see photo)
    • Once the iSesamo is inserted, slide it along the sides to remove the adhesive.
    • ATTENTION: DO NOT SLIDE THE ISESEMO ALONG THE PART MARKED IN GREEN.
  2. Huawei Honor 8 Screen Replacement, Disconnect the rear window: step 2, image 1 of 2 Huawei Honor 8 Screen Replacement, Disconnect the rear window: step 2, image 2 of 2
    • Remove the screw on the metal plate which protects the fingerprint sensor cable
    • Remove the the fingerprint censor cable using a plastic spudger.
  3. Huawei Honor 8 Screen Replacement, Remove the protection from the motherboard: step 3, image 1 of 3 Huawei Honor 8 Screen Replacement, Remove the protection from the motherboard: step 3, image 2 of 3 Huawei Honor 8 Screen Replacement, Remove the protection from the motherboard: step 3, image 3 of 3
    • Remove the 16 screws with a Phillips screwdriver.
    • Using the iSesamo, remove the protection from the motherboard
  4. Huawei Honor 8 Screen Replacement, Take off the battery: step 4, image 1 of 3 Huawei Honor 8 Screen Replacement, Take off the battery: step 4, image 2 of 3 Huawei Honor 8 Screen Replacement, Take off the battery: step 4, image 3 of 3
    • Remove the 2 tabs marked in red.
    • Gently remove the battery with a playing card or bank card.
  5. Huawei Honor 8 Screen Replacement, Prepare to take off the screen: step 5, image 1 of 2 Huawei Honor 8 Screen Replacement, Prepare to take off the screen: step 5, image 2 of 2
    • Peel off the connector on the screen.
    • Heat the contours of the screen as shown in Step 1.
  6. Huawei Honor 8 Screen Replacement, Take off the screen: step 6, image 1 of 2 Huawei Honor 8 Screen Replacement, Take off the screen: step 6, image 2 of 2
    • insert the iSesamo between the screen and the chassis
    • Be sure to pass the iSesamo under the white plate of the screen (see photo)
    • Go around the phone.
    • Note that the operation can be more complicated depending on the level of the screen.
  7. Huawei Honor 8 Screen Replacement, Clean the frame: step 7, image 1 of 2 Huawei Honor 8 Screen Replacement, Clean the frame: step 7, image 2 of 2
    • Carefully remove the pieces of glass and the adhesive on the frame
    • Glue the screen on the frame by passing the sheet through the hole provided for this purpose
To reassemble your device, follow the instructions in reverse order :)
4 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Nihoul Victor
261 Reputation
1 Guide authored
4 Guide Comments
Est-ce que quelqu'un a essayer ? a combien estimez vous la réparation: ecran + accessoires ? Car le lien ne fonctionne pas. En tout cas tuto très bien réalisé ;)
fabien6-8ol - Reply
Moi forcement ...
Chez moi le lien fonctionne, la pièce est à 55,99€, tu peux demander des accessoires gratuit
Nihoul Victor - Reply
Sinon merci ;)
Bonjour
Merci pour ce tuto. J'aurais juste une question.
Comment recollé la vitre arrière après la réparation ?
J'ai déjà eu le cas sur un smartphone Sony et je n'ai pas réussi à correctement recollé la face arrière.
Merci a bientôt
Comoretto Quentin - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 5,335
