Huawei M750 Camera Replacement
  1. Huawei M750 Camera Replacement, Battery: step 1, image 1 of 1
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Huawei M750 Camera Replacement: step 2, image 1 of 1
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. Huawei M750 Camera Replacement, Back Panel: step 3, image 1 of 1
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  4. Huawei M750 Camera Replacement: step 4, image 1 of 2 Huawei M750 Camera Replacement: step 4, image 2 of 2
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  5. Huawei M750 Camera Replacement: step 5, image 1 of 2 Huawei M750 Camera Replacement: step 5, image 2 of 2
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
  6. Huawei M750 Camera Replacement, Camera: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • The camera's connection to the motherboard is shown here.
    • Using the tweezers, disconnect the port, shown here in the picture.
  7. Huawei M750 Camera Replacement: step 7, image 1 of 1
    • Using the tweezers, carefully remove the lens and lens casing.
    • It should be held in by a simple tight fit. The front panel is what keeps the lens secured.
    • Do not touch the camera lens, or the digital camera component, if possible. This will prevent scratching, or damage.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 291
