Huawei M750 Charging Port Replacement
  1. Huawei M750 Charging Port Replacement, Battery: step 1, image 1 of 1
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Huawei M750 Charging Port Replacement: step 2, image 1 of 1
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. Huawei M750 Charging Port Replacement, Back Panel: step 3, image 1 of 1
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  4. Huawei M750 Charging Port Replacement: step 4, image 1 of 2 Huawei M750 Charging Port Replacement: step 4, image 2 of 2
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  5. Huawei M750 Charging Port Replacement: step 5, image 1 of 2 Huawei M750 Charging Port Replacement: step 5, image 2 of 2
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
  6. Huawei M750 Charging Port Replacement, Charging Port: step 6, image 1 of 2 Huawei M750 Charging Port Replacement, Charging Port: step 6, image 2 of 2
    • Using the opening tool, start prying out the motherboard from the front panel along the border.
    • When the motherboard seems separated from the front panel, pull it outwards.
  7. Huawei M750 Charging Port Replacement: step 7, image 1 of 2 Huawei M750 Charging Port Replacement: step 7, image 2 of 2
    • The charging port is soldered to the motherboard, use this guide to do the replacement.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 260
