Huawei Mate 10 Screen Replacement
  1. Huawei Mate 10 Screen Replacement, Remove the back cover: step 1, image 1 of 3 Huawei Mate 10 Screen Replacement, Remove the back cover: step 1, image 2 of 3 Huawei Mate 10 Screen Replacement, Remove the back cover: step 1, image 3 of 3
    • Heat an iOpener and apply it to the bottom edge of the phone for two minutes. Re-heat the iOpener as needed.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone.
    • While you wait, note the location of the adhesive holding the back cover in place.
  2. Huawei Mate 10 Screen Replacement: step 2, image 1 of 3 Huawei Mate 10 Screen Replacement: step 2, image 2 of 3 Huawei Mate 10 Screen Replacement: step 2, image 3 of 3
    • Place a suction cup near the bottom edge of the back cover, on the right side (opposite the speaker grille) of the USB-C charging port, above the microphone hole.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. If all else fails, you can superglue the suction cup to the back cover.
    • Pull on the suction cup with strong, steady force to create a gap.
    • Due to the adhesive's strength, this is very difficult and may take multiple attempts. If you can't create a gap, re-apply heat and try again.
    • Insert the point of an opening pick into the gap.
  3. Huawei Mate 10 Screen Replacement: step 3, image 1 of 3 Huawei Mate 10 Screen Replacement: step 3, image 2 of 3 Huawei Mate 10 Screen Replacement: step 3, image 3 of 3
    • Slide the pick along the bottom edge and around the bottom-left corner, slicing through the adhesive.
    • If the adhesive feels tacky and difficult to slice, re-apply heat to the edge and try again.
    • Leave an opening pick in the seam to prevent the edge from re-sealing.
  4. Huawei Mate 10 Screen Replacement: step 4, image 1 of 3 Huawei Mate 10 Screen Replacement: step 4, image 2 of 3 Huawei Mate 10 Screen Replacement: step 4, image 3 of 3
    • Apply a heated iOpener to the left edge of the phone.
    • Use an opening pick to slice through the adhesive on the left edge of the phone.
    • The adhesive is very thick in some areas. Sustained exposure to heat will help weaken the stubborn adhesive. Take your time, and apply heat liberally.
  5. Huawei Mate 10 Screen Replacement: step 5, image 1 of 2 Huawei Mate 10 Screen Replacement: step 5, image 2 of 2
    • Continue heating and slicing through the remaining edges, leaving opening picks in the seams to prevent the adhesive from re-sealing.
  6. Huawei Mate 10 Screen Replacement: step 6, image 1 of 3 Huawei Mate 10 Screen Replacement: step 6, image 2 of 3 Huawei Mate 10 Screen Replacement: step 6, image 3 of 3
    • After you cut through the adhesive around the entire perimeter of the back cover, begin to lift it away from the phone.
    • Use an opening pick to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  7. Huawei Mate 10 Screen Replacement, Prep the phone for a new back cover: step 7, image 1 of 2 Huawei Mate 10 Screen Replacement, Prep the phone for a new back cover: step 7, image 2 of 2
    • Before you install a replacement back cover, be sure to remove all traces of perimeter adhesive from the phone frame.
    • If you are re-using the back cover, carefully remove all traces of adhesive from the back cover.
    • The glass back cover is fragile and prone to cracking. Don't apply uneven pressure to the back cover as you clean.
    • You may pull up chunks of the cover's color coating as you remove the adhesive. To reduce the chances of this occurring, apply heat or high concentration isopropyl alcohol to the adhesive to weaken it.
  8. Huawei Mate 10 Screen Replacement: step 8, image 1 of 2 Huawei Mate 10 Screen Replacement: step 8, image 2 of 2
    • If your replacement back cover did not come with a flash diffuser or camera bezel, you will need to transfer them from your old cover to the new one.
    • Apply a heated iOpener directly over the bezels for a minute.
    • Use an opening pick to slice around the flash diffuser to loosen the adhesive.
    • The flash diffuser is made of plastic and cracks easily. Be sure to slice around the flash completely before you pry it off.
    • Use an opening tool to pry up and remove the camera bezel.
    • Transfer the parts to your replacement cover.
  9. Huawei Mate 10 Screen Replacement, Remove the plastic bracket: step 9, image 1 of 2 Huawei Mate 10 Screen Replacement, Remove the plastic bracket: step 9, image 2 of 2
    • The next two steps show how to remove the heat dissipation layer, along with its plastic bracket.
    • Remove the eight 3.4 mm long Phillips screws securing the plastic bracket.
    • One screw lies beneath a white sticker. Remove the sticker.
    • Insert the point of a spudger underneath the right edge of the plastic bracket and pry up slightly to loosen the shield.
  10. Huawei Mate 10 Screen Replacement: step 10, image 1 of 3 Huawei Mate 10 Screen Replacement: step 10, image 2 of 3 Huawei Mate 10 Screen Replacement: step 10, image 3 of 3
    • Grasp the the lower edge of the plastic bracket with your fingers and lift the edge up slightly.
    • Pull the plastic bracket away from the top edge of the phone.
    • Slowly peel the black heat dissipation layer away from the phone. It is held in place with small patches of adhesive.
    • Remove the plastic bracket along with the heat dissipation layer.
  11. Huawei Mate 10 Screen Replacement, Disconnect the battery: step 11, image 1 of 2 Huawei Mate 10 Screen Replacement, Disconnect the battery: step 11, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  12. Huawei Mate 10 Screen Replacement, Disconnect the interconnect cable: step 12, image 1 of 2 Huawei Mate 10 Screen Replacement, Disconnect the interconnect cable: step 12, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the wide interconnect flex cable from its motherboard socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. Huawei Mate 10 Screen Replacement: step 13, image 1 of 2 Huawei Mate 10 Screen Replacement: step 13, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the fingerprint extension cable from its motherboard socket.
  14. Huawei Mate 10 Screen Replacement, Disconnect the button connector: step 14, image 1 of 1
    • Use the point of a spudger to pry up and disconnect the button connector from its motherboard socket.
  15. Huawei Mate 10 Screen Replacement, Remove the glued-in battery: step 15, image 1 of 2 Huawei Mate 10 Screen Replacement, Remove the glued-in battery: step 15, image 2 of 2
    • The battery is held in place by very strong adhesive.
    • Apply a heated iOpener to the left side of the phone screen for a minute.
    • While you wait, note where the U-shaped adhesive resides on the phone frame.
  16. Huawei Mate 10 Screen Replacement: step 16, image 1 of 3 Huawei Mate 10 Screen Replacement: step 16, image 2 of 3 Huawei Mate 10 Screen Replacement: step 16, image 3 of 3
    • Insert an opening pick in the notch on the phone's right edge.
    • Slowly but firmly push the pick underneath the battery, to loosen it from the frame.
    • If you are having trouble getting the pick under the battery, you can apply some high concentration isopropyl alcohol to the seam. Give the alcohol a minute to penetrate and soften the adhesive.
  17. Huawei Mate 10 Screen Replacement: step 17, image 1 of 2 Huawei Mate 10 Screen Replacement: step 17, image 2 of 2
    • Slowly insert an opening pick in the top edge of the battery, towards the right edge.
    • Twist slightly to help loosen the battery.
  18. Huawei Mate 10 Screen Replacement: step 18, image 1 of 3 Huawei Mate 10 Screen Replacement: step 18, image 2 of 3 Huawei Mate 10 Screen Replacement: step 18, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Insert a plastic card under the battery's right edge.
    • Push the card inwards to loosen the battery from the frame.
    • If you're having a hard time loosening the battery, you can apply more isopropyl alcohol, or try to soften the adhesive with more heat.
    • Try not to deform the battery as you pry.
  19. Huawei Mate 10 Screen Replacement: step 19, image 1 of 3 Huawei Mate 10 Screen Replacement: step 19, image 2 of 3 Huawei Mate 10 Screen Replacement: step 19, image 3 of 3
    • Once the battery is sufficiently loosened from the frame, slowly lift it out.
    • Remove the battery.
    • To install a replacement battery:
    • Apply new adhesive to the phone frame.
    • Gently lay the battery pack in the phone.
    • Temporarily reconnect the battery to the motherboard to ensure that the battery is properly aligned.
    • Once the battery is aligned, press it firmly in place with your fingers. Disconnect the battery from the motherboard, and resume re-assembly.
    • For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
  20. Huawei Mate 10 Screen Replacement, Remove the loudspeaker: step 20, image 1 of 2 Huawei Mate 10 Screen Replacement, Remove the loudspeaker: step 20, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the white antenna cable from the bottom of the phone.
  21. Huawei Mate 10 Screen Replacement: step 21, image 1 of 1
    • Remove the six 3.4 mm Phillips screws holding the loudspeaker in place.
  22. Huawei Mate 10 Screen Replacement: step 22, image 1 of 2 Huawei Mate 10 Screen Replacement: step 22, image 2 of 2
    • The loudspeaker is still held in place by adhesive and clips.
    • Insert an opening pick underneath the right edge of the loudspeaker assembly.
    • Carefully slide the opening pick under the right half of the assembly to loosen the clips.
  23. Huawei Mate 10 Screen Replacement: step 23, image 1 of 3 Huawei Mate 10 Screen Replacement: step 23, image 2 of 3 Huawei Mate 10 Screen Replacement: step 23, image 3 of 3
    • Grasp the loosened edge of the loudspeaker and gently pull the assembly away from the bottom edge of the phone.
    • You may need to wiggle the assembly a little to loosen it from the frame.
    • Remove the loudspeaker.
  24. Huawei Mate 10 Screen Replacement, Remove the daughterboard: step 24, image 1 of 3 Huawei Mate 10 Screen Replacement, Remove the daughterboard: step 24, image 2 of 3 Huawei Mate 10 Screen Replacement, Remove the daughterboard: step 24, image 3 of 3
    • Insert the point of a spudger in one of the notches along the bottom edge of the daughterboard.
    • Push the daughterboard away from the bottom of the phone to loosen the board.
    • Repeat the process with a second notch to fully release the daughterboard.
  25. Huawei Mate 10 Screen Replacement: step 25, image 1 of 1
    • Remove the daughterboard.
  26. Huawei Mate 10 Screen Replacement, Disconnect the screen cable: step 26, image 1 of 2 Huawei Mate 10 Screen Replacement, Disconnect the screen cable: step 26, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket.
  27. Huawei Mate 10 Screen Replacement: step 27, image 1 of 3 Huawei Mate 10 Screen Replacement: step 27, image 2 of 3 Huawei Mate 10 Screen Replacement: step 27, image 3 of 3
    • Grasp the display cable with your fingers and gently pull it away from the phone frame.
  28. Huawei Mate 10 Screen Replacement, Disconnect the fingerprint sensor cable: step 28, image 1 of 3 Huawei Mate 10 Screen Replacement, Disconnect the fingerprint sensor cable: step 28, image 2 of 3 Huawei Mate 10 Screen Replacement, Disconnect the fingerprint sensor cable: step 28, image 3 of 3
    Buy
    • Use tweezers to peel the tape covering the fingerprint sensor cable connector near the bottom edge of the phone.
    • The cable is held in place with a ZIF socket.
    • Use the point of a spudger to flip up the gray bar on the socket to unlock the cable.
  29. Huawei Mate 10 Screen Replacement: step 29, image 1 of 2 Huawei Mate 10 Screen Replacement: step 29, image 2 of 2
    • Use tweezers to grasp the cable's brown pull tab and pull the cable out of the socket.
    • To reinstall the fingerprint sensor cable:
    • Align and push the cable back into the connector, up to the white line marked on the cable.
    • Carefully flip the gray bar on the socket down to lock the cable in place.
  30. Huawei Mate 10 Screen Replacement, Remove the screen: step 30, image 1 of 1
    • The next steps show how to remove the heavily glued screen from the phone. While it is possible to replace the top glass alone, it is very difficult to accomplish without damaging the LCD.
    • Apply a heated iOpener to the left edge of the phone for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used. Since you don't need to worry about overheating the battery or screen, you can apply more heat than usual.
  31. Huawei Mate 10 Screen Replacement: step 31, image 1 of 3 Huawei Mate 10 Screen Replacement: step 31, image 2 of 3 Huawei Mate 10 Screen Replacement: step 31, image 3 of 3
    • Place a suction cup near the bottom left corner of the phone. The edge there has slightly thinner adhesive.
    • Pull on the suction cup with strong, steady force to create a gap in the seam.
    • Insert an opening pick in the gap.
    • Depending on how old your phone is, creating this initial gap may be very difficult. Here are some things you can try if you're having trouble:
    • Repeat the heating and pulling process multiple times to soften the adhesive.
    • Use a playing card instead of an opening pick to insert in the gap.
    • Try heating and prying at a different location.
    • Use a Jimmy to make the initial entry. Be careful working with metal tools, as they will scratch the frame and chip the glass screen.
  32. Huawei Mate 10 Screen Replacement: step 32, image 1 of 3 Huawei Mate 10 Screen Replacement: step 32, image 2 of 3 Huawei Mate 10 Screen Replacement: step 32, image 3 of 3
    • Once you've made the initial entry, slice through the left, top, and right phone edges. Apply heat to help soften the adhesive.
    • The top edge has adhesive that's as thick as the bezel. Make sure to slice through all of the adhesive.
  33. Huawei Mate 10 Screen Replacement: step 33, image 1 of 3 Huawei Mate 10 Screen Replacement: step 33, image 2 of 3 Huawei Mate 10 Screen Replacement: step 33, image 3 of 3
    • As you slice through the bottom edge, be careful not to slice near the right edge of the fingerprint sensor. It contains the sensor ribbon, which is prone to damage.
    • Slice through the bottom edge of the phone, making sure to skip the fingerprint sensor area as marked.
  34. Huawei Mate 10 Screen Replacement: step 34, image 1 of 3 Huawei Mate 10 Screen Replacement: step 34, image 2 of 3 Huawei Mate 10 Screen Replacement: step 34, image 3 of 3
    • Once you have sliced around the perimeter, grasp the screen from the top corners and lift up.
    • Use an opening pick to slice through any remaining adhesive holding onto the screen.
    • Carefully thread the fingerprint sensor cable and the display cable through their respective cutouts in the phone's frame.
  35. Huawei Mate 10 Screen Replacement: step 35, image 1 of 1
    • Remove the screen.
    • You may need to transfer the fingerprint sensor to your new screen. Follow the next step to remove the fingerprint sensor.
  36. Huawei Mate 10 Screen Replacement, Remove the fingerprint sensor: step 36, image 1 of 3 Huawei Mate 10 Screen Replacement, Remove the fingerprint sensor: step 36, image 2 of 3 Huawei Mate 10 Screen Replacement, Remove the fingerprint sensor: step 36, image 3 of 3
    • Position your finger or the flat end of a spudger on the fingerprint sensor's backside and push gently to dislodge the sensor.
    • Carefully thread the sensor cable through the screen's cutout.
    • Remove the fingerprint sensor.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mate 10 Answers community for help.
8 other people completed this guide.
Arthur Shi
323,262 Reputation
793 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,220 Guides authored
3 Guide Comments
Bjr alors je vient de changer l'écran sur mon Huawei mate 10 pro… LeLe problème c'est qu'il faut appuyer plusieurs fois sur le bouton power pour que l'écran afficher je sais pas où il est le problème pouvait vous m'aide et merci
Benbouali houmame - Reply Share
thank you, for this information........... definately sending mine to the professionals.
Murray Reid - Reply Share
شكرا. جيدجدا. اتمنى اكثر
arkank018 - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 120
All Time: 9,551
