Huawei Mate 8 Display Replacement
  1. Huawei Mate 8 Display Replacement, Back Cover: step 1, image 1 of 2 Huawei Mate 8 Display Replacement, Back Cover: step 1, image 2 of 2
    • Switch off your phone and remove the SIM card tray.
  2. Huawei Mate 8 Display Replacement: step 2, image 1 of 1
    • Remove the Torx T2 screws from the bottom of the phone
  3. Huawei Mate 8 Display Replacement: step 3, image 1 of 2 Huawei Mate 8 Display Replacement: step 3, image 2 of 2
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Huawei Mate 8 Display Replacement: step 4, image 1 of 3 Huawei Mate 8 Display Replacement: step 4, image 2 of 3 Huawei Mate 8 Display Replacement: step 4, image 3 of 3
    • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
  5. Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: step 5, image 1 of 3 Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: step 5, image 2 of 3 Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: step 5, image 3 of 3
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  6. Huawei Mate 8 Display Replacement: step 6, image 1 of 3 Huawei Mate 8 Display Replacement: step 6, image 2 of 3 Huawei Mate 8 Display Replacement: step 6, image 3 of 3
    • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  7. Huawei Mate 8 Display Replacement: step 7, image 1 of 1
    • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  8. Huawei Mate 8 Display Replacement: step 8, image 1 of 2 Huawei Mate 8 Display Replacement: step 8, image 2 of 2
    • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
    • Remove the bracket.
  9. Huawei Mate 8 Display Replacement: step 9, image 1 of 1
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
  10. Huawei Mate 8 Display Replacement, Battery: step 10, image 1 of 1
    • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
    • Get a good grip on the pull tab near the power button and peel out the adhesive strip by steadily pulling at the tab in a flat angle.
    • If the adhesive strip rips, grab and twist it around the tweezer tips a couple of times and then continue.
  11. Huawei Mate 8 Display Replacement: step 11, image 1 of 3 Huawei Mate 8 Display Replacement: step 11, image 2 of 3 Huawei Mate 8 Display Replacement: step 11, image 3 of 3
    • Do not bend or puncture the battery, damage to the cell can cause battery fires.
    • Heat an iOpener and place it on the phone for about a minute to loosen the remaining adhesive.
    • Carefully insert the flat end of a spudger to separate any remaining adhesive at the top of the battery.
  12. Huawei Mate 8 Display Replacement: step 12, image 1 of 2 Huawei Mate 8 Display Replacement: step 12, image 2 of 2
    • Lift the top end of the battery to pull the battery off of the remaining adhesive strip.
    • When reassembling your phone, apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
    • Never reinstall a battery that has been bent or damaged during removal.
  13. Huawei Mate 8 Display Replacement, Display: step 13, image 1 of 1
    • Remove the four Phillips #00 screws holding the daughterboard and loudspeaker to the phone.
  14. Huawei Mate 8 Display Replacement: step 14, image 1 of 2 Huawei Mate 8 Display Replacement: step 14, image 2 of 2
    • Use the flat end of a spudger to disconnect the loudspeaker connector cable.
    • Use the tip of a spudger to lift the daughterboard from the phone.
  15. Huawei Mate 8 Display Replacement: step 15, image 1 of 2 Huawei Mate 8 Display Replacement: step 15, image 2 of 2
    Tool used on this step:
    Buy
    • Insert the flat end of a spudger under the loudspeaker at the gap on the left side.
    • Work the spudger under the loudspeaker to seperate it from the adhesive and remove the loudspeaker.
    • Use tweezers to take the vibration unit out of its housing.
  16. Huawei Mate 8 Display Replacement: step 16, image 1 of 1
    • Remove the eight Phillips #00 screws securing the motherboard to the phone.
  17. Huawei Mate 8 Display Replacement: step 17, image 1 of 2 Huawei Mate 8 Display Replacement: step 17, image 2 of 2
    • Remove the bracket from the rear camera flex cable.
    • Use tweezers to disconnect the antenna cable.
  18. Huawei Mate 8 Display Replacement: step 18, image 1 of 3 Huawei Mate 8 Display Replacement: step 18, image 2 of 3 Huawei Mate 8 Display Replacement: step 18, image 3 of 3
    • Use the flat end of a spudger to disconnect the volume and power flex cable on the bottom left side of the mainboard.
    • Work the flat end of a spudger under the top right side of the mainboard to pry it out.
    • Remove the mainboard.
  19. Huawei Mate 8 Display Replacement: step 19, image 1 of 2 Huawei Mate 8 Display Replacement: step 19, image 2 of 2
    • Remove the antenna interconnect cable.
    • Remove the power and volume switch assembly.
  20. Huawei Mate 8 Display Replacement: step 20, image 1 of 3 Huawei Mate 8 Display Replacement: step 20, image 2 of 3 Huawei Mate 8 Display Replacement: step 20, image 3 of 3
    • Use tweezers to remove the earpiece speaker.
    • Remove the red rubber gasket.
    • Remove the ambient light and proximity sensor.
9 other people completed this guide.
Dominik Schnabelrauch
250,135 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
125 Members
24,015 Guides authored
1 Guide Comment
Tidy. Really tidy like.
Marc Vestabule - Reply
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 89
All Time: 6,662
