Huawei Mate 9 Motherboard Replacement
  1. Huawei Mate 9 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Huawei Mate 9 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Huawei Mate 9 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Turn off your Huawei Mate 9 smartphone.
    • Remove the SIM card tray with a SIM card removal tool.
    • Remove the two T2 screws at the base of the phone next to the USB Type- C port with a T2 Torx Screwdriver.
  2. Huawei Mate 9 Motherboard Replacement: step 2, image 1 of 3 Huawei Mate 9 Motherboard Replacement: step 2, image 2 of 3 Huawei Mate 9 Motherboard Replacement: step 2, image 3 of 3
    • Using a suction cup, carefully start pulling the display assembly from the back cover.
    • Insert a pick when pulling the display assembly off the back cover, while sliding the pick along the edge of the phone to loosen the display assembly.
    • While removing the display assembly, make sure to not completely remove the back cover. This is due to the power button and fingerprint sensor cables still being connected to the motherboard.
  3. Huawei Mate 9 Motherboard Replacement: step 3, image 1 of 2 Huawei Mate 9 Motherboard Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • To protect the internal cables and components, you will need to carefully disconnect the battery connector.
    • Use a Phillips #000 screwdriver to remove the 1.3 mm screws securing the metal plate.
    • Remove the metal plate with tweezers.
    • Disconnect the battery connector from the motherboard using the spudger.
  4. Huawei Mate 9 Motherboard Replacement: step 4, image 1 of 2 Huawei Mate 9 Motherboard Replacement: step 4, image 2 of 2
    • Using a spudger, disconnect the battery connector.
    • Remove the back cover.
  5. Huawei Mate 9 Motherboard Replacement: step 5, image 1 of 3 Huawei Mate 9 Motherboard Replacement: step 5, image 2 of 3 Huawei Mate 9 Motherboard Replacement: step 5, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the two 1.0 mm screws securing the metal plate.
    • After removing the metal plate, you can now remove the rear camera from its slot.
  6. Huawei Mate 9 Motherboard Replacement: step 6, image 1 of 2 Huawei Mate 9 Motherboard Replacement: step 6, image 2 of 2
    • To remove the front-facing camera, peel off the conducting fabric from the metal shield on the display assembly.
    • Disconnect the front camera connector and remove the front-facing camera.
  7. Huawei Mate 9 Motherboard Replacement: step 7, image 1 of 3 Huawei Mate 9 Motherboard Replacement: step 7, image 2 of 3 Huawei Mate 9 Motherboard Replacement: step 7, image 3 of 3
    • Use a Phillips #000 to remove the six 1.0 mm screws securing the motherboard.
    • Use a spudger to disconnect the coaxial antenna cables.
    • Disconnect the remaining cables using a spudger.
    • Remove the motherboard completely.
4 other people completed this guide.
Rogelio Ramirez
524 Reputation
3 Guides authored
UC Davis, Team S7-G8, Lore Fall 2018 Member of UC Davis, Team S7-G8, Lore Fall 2018
UCD-LORE-F18S7G8
3 Members
6 Guides authored
One Comment
Where can I find a replacement motherboard for the Huawei mate 9,eBay doesn't seem to have any.
Mobin Stone Bulaya - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 44
All Time: 2,773
