Huawei MediaPad M3 Battery Replacement
  1. Huawei MediaPad M3 Battery Replacement, Battery: step 1, image 1 of 1
    • Using the Jimmy tool, gently pry the display open.
    • Wear ESD bracelet to ensure you are electrostatic safe.
  2. Huawei MediaPad M3 Battery Replacement: step 2, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the six 3.0mm screws.
  3. Huawei MediaPad M3 Battery Replacement: step 3, image 1 of 1
    • Using the tweezer tool, remove the ribbon cable attached to the main display in two places.
  4. Huawei MediaPad M3 Battery Replacement: step 4, image 1 of 3 Huawei MediaPad M3 Battery Replacement: step 4, image 2 of 3 Huawei MediaPad M3 Battery Replacement: step 4, image 3 of 3
    • Using the tweezer tool, remove the three remaining ribbon cables.
  5. Huawei MediaPad M3 Battery Replacement: step 5, image 1 of 1
    • Using the Jimmy, break the adhesive that holds the battery to the main body and remove the battery from the device.
7 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 44
Past 30 Days: 128
All Time: 7,027
