Huawei MediaPad S7-301u Battery Replacement
  1. Huawei MediaPad S7-301u Battery Replacement, Battery: step 1, image 1 of 3 Huawei MediaPad S7-301u Battery Replacement, Battery: step 1, image 2 of 3 Huawei MediaPad S7-301u Battery Replacement, Battery: step 1, image 3 of 3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Battery Replacement: step 2, image 1 of 1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Battery Replacement: step 3, image 1 of 3 Huawei MediaPad S7-301u Battery Replacement: step 3, image 2 of 3 Huawei MediaPad S7-301u Battery Replacement: step 3, image 3 of 3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Battery Replacement: step 4, image 1 of 3 Huawei MediaPad S7-301u Battery Replacement: step 4, image 2 of 3 Huawei MediaPad S7-301u Battery Replacement: step 4, image 3 of 3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
5 other people completed this guide.
Miguel Lugo
598 Reputation
3 Guides authored
USF Tampa, Team S11-G5, Passmore Fall 2017 Member of USF Tampa, Team S11-G5, Passmore Fall 2017
USFT-PASSMORE-F17S11G5
4 Members
8 Guides authored
One Comment
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
marcusinho_ab - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 7,245
