Huawei P10 Back Cover Replacement
  1. Huawei P10 Back Cover Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Back Cover Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Back Cover Replacement, Back Cover: step 1, image 3 of 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Back Cover Replacement: step 2, image 1 of 3 Huawei P10 Back Cover Replacement: step 2, image 2 of 3 Huawei P10 Back Cover Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Back Cover Replacement: step 3, image 1 of 2 Huawei P10 Back Cover Replacement: step 3, image 2 of 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
6 other people completed this guide.
Dominik Schnabelrauch
248,015 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,791 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 30
All Time: 8,580
