Huawei P10 Battery Replacement
  1. Huawei P10 Battery Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Battery Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Battery Replacement, Back Cover: step 1, image 3 of 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Battery Replacement: step 2, image 1 of 3 Huawei P10 Battery Replacement: step 2, image 2 of 3 Huawei P10 Battery Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Battery Replacement: step 3, image 1 of 2 Huawei P10 Battery Replacement: step 3, image 2 of 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the two Phillips #00 screws.
  5. Huawei P10 Battery Replacement: step 5, image 1 of 2 Huawei P10 Battery Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the two cable brackets.
  6. Huawei P10 Battery Replacement: step 6, image 1 of 3 Huawei P10 Battery Replacement: step 6, image 2 of 3 Huawei P10 Battery Replacement: step 6, image 3 of 3
    • Use a spudger to disconnect the battery, the interconnect and the display flex cable.
  7. Huawei P10 Battery Replacement: step 7, image 1 of 2 Huawei P10 Battery Replacement: step 7, image 2 of 2
    • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
    • Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
    • It is likely that the adhesive strip rips. In this case you can grab and twist it around a tweezers tip a couple of times and then continue.
    • Use an iOpener to loosen the remaining adhesive.
  8. Huawei P10 Battery Replacement: step 8, image 1 of 2 Huawei P10 Battery Replacement: step 8, image 2 of 2
    Tesa 61395 Tape
    $5.99
    Buy
    • Take care to not bend or puncture the battery.
    • Insert an opening pick or spudger beneath the battery and carefully pry it out.
    • Remove the battery.
    • When reassembling your phone, replace old adhesive with stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
    • Never reinstall a battery that has been bent or damaged during removal.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
82 other people completed this guide.
Dominik Schnabelrauch
248,342 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
16 Guide Comments
Thanks for posting this this give me new ideas.
Dave Dayanan - Reply
Facile comme bonjour. Les outils que j'avais reçu avec la batterie étaient de piètre qualité, j'ai donc utilisé des mini-spatules utilisées pour lisser les joints en silicone, c'est pile la consistance voulue pour décoller le dos et la batterie, ni trop ferme ni trop souple.
lepisosteus74 - Reply
Easy fix, thanks a lot.
Noé Barreau - Reply
Excellent guide, was done in 20 minutes, thankyou!
Mog Kupo - Reply
Eccellente guida peccato che una volta montata la nuova batteria in cellulare si sente che si accende la il display rimane buio, controllato connessioni ma sono tutte ok e display sempre spento, cosa può essere?
Adriano
Adriano Da Rold - Reply
Past 24 Hours: 16
Past 7 Days: 69
Past 30 Days: 224
All Time: 70,485
