Huawei P10 Display Replacement
  1. Huawei P10 Display Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Display Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Display Replacement, Back Cover: step 1, image 3 of 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Display Replacement: step 2, image 1 of 3 Huawei P10 Display Replacement: step 2, image 2 of 3 Huawei P10 Display Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Display Replacement: step 3, image 1 of 2 Huawei P10 Display Replacement: step 3, image 2 of 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Display Replacement, Main and display flex disconnect: step 4, image 1 of 3 Huawei P10 Display Replacement, Main and display flex disconnect: step 4, image 2 of 3 Huawei P10 Display Replacement, Main and display flex disconnect: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two Phillips #00 screws.
    • Use tweezers to remove both metal plates.
  5. Huawei P10 Display Replacement: step 5, image 1 of 3 Huawei P10 Display Replacement: step 5, image 2 of 3 Huawei P10 Display Replacement: step 5, image 3 of 3
    • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
  6. Huawei P10 Display Replacement, Charging Board: step 6, image 1 of 2 Huawei P10 Display Replacement, Charging Board: step 6, image 2 of 2
    Buy
    • Remove the four Phillips #00 screws.
    • Use Tweezers to remove the metal plate.
  7. Huawei P10 Display Replacement: step 7, image 1 of 2 Huawei P10 Display Replacement: step 7, image 2 of 2
    • Use a spudger to disconnect the main flex cable.
    • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
  8. Huawei P10 Display Replacement: step 8, image 1 of 2 Huawei P10 Display Replacement: step 8, image 2 of 2
    • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
  9. Huawei P10 Display Replacement: step 9, image 1 of 2 Huawei P10 Display Replacement: step 9, image 2 of 2
    • Do not damage any components sitting on the charging board while removing it.
    • Use a spudger to pry out the charging board.
    • Remove the charging board.
  10. Huawei P10 Display Replacement, Loudspeaker: step 10, image 1 of 2 Huawei P10 Display Replacement, Loudspeaker: step 10, image 2 of 2
    • Only insert the spudger as deep as 1/16 of an inch to avoid damage.
    • Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can use an iOpener to loosen it.
    • Remove the loudspeaker.
    • When reassembling your phone, apply new adhesive where it's necessary.
  11. Huawei P10 Display Replacement, Display: step 11, image 1 of 2 Huawei P10 Display Replacement, Display: step 11, image 2 of 2
    Buy
    • Remove the antenna cable if you haven't already.
    • Use tweezers to remove the interconnect cable.
    • Use an iOpener to loosen the adhesive beneath the display. Especially take care of the upper and lower part of the display.
  12. Huawei P10 Display Replacement: step 12, image 1 of 3 Huawei P10 Display Replacement: step 12, image 2 of 3 Huawei P10 Display Replacement: step 12, image 3 of 3
    • Insert the tip of an opening pick between the display and the midframe on the bottom of the phone, near the home button.
    • Slide the opening pick along the bottom edge, to cut the adhesive.
    • Slide the opening pick to the bottom right corner and leave it there.
    • Insert another opening pick under the screen on the bottom left corner.
  13. Huawei P10 Display Replacement: step 13, image 1 of 3 Huawei P10 Display Replacement: step 13, image 2 of 3 Huawei P10 Display Replacement: step 13, image 3 of 3
    • Slide the opening pick under the screen around all edges of the phone.
    • If the adhesive gets tough to pry it is likely too cold. Use your iOpener or heat gun to reheat it.
  14. Huawei P10 Display Replacement: step 14, image 1 of 2 Huawei P10 Display Replacement: step 14, image 2 of 2
    • Carefully pull the display assembly away from the frame.
    • Remove the display assembly.
23 other people completed this guide.
Dominik Schnabelrauch
248,242 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
4 Guide Comments
Any advice which adhesive to use? I’ve seen a russian replacement video, it looked like the guy was using some kind of silicone.
Tom My - Reply
I used B-7000 glue. It enables you to release the screen when a second replacement is needed.
teunkeusters -
Assuming I purchase a screen off of ebay, and replace it using this method, will the touch id still work?
Simon Fisher - Reply
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 109
All Time: 28,210
