Huawei P10 Headphone Jack Replacement
  1. Huawei P10 Headphone Jack Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Headphone Jack Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Headphone Jack Replacement, Back Cover: step 1, image 3 of 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Headphone Jack Replacement: step 2, image 1 of 3 Huawei P10 Headphone Jack Replacement: step 2, image 2 of 3 Huawei P10 Headphone Jack Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Headphone Jack Replacement: step 3, image 1 of 2 Huawei P10 Headphone Jack Replacement: step 3, image 2 of 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Headphone Jack Replacement, Battery disconnect: step 4, image 1 of 3 Huawei P10 Headphone Jack Replacement, Battery disconnect: step 4, image 2 of 3 Huawei P10 Headphone Jack Replacement, Battery disconnect: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Huawei P10 Headphone Jack Replacement, Headphone Jack: step 5, image 1 of 2 Huawei P10 Headphone Jack Replacement, Headphone Jack: step 5, image 2 of 2
    Buy
    • Remove the three Phillips #00 screws.
  6. Huawei P10 Headphone Jack Replacement: step 6, image 1 of 2 Huawei P10 Headphone Jack Replacement: step 6, image 2 of 2
    • Use the flat end of a spudger to disconnect the headphone jack.
    • Remove the headphone jack.
    • There is a small piece of adhesive underneath, so it might be a little bit sticky. You can use an iOpener to loosen the adhesive and make the removal easier.
    • When reassembling apply new adhesive where it's necessary.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
2 other people completed this guide.
Dominik Schnabelrauch
210,056 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 2,928
