Huawei P20 Battery Replacement
  1. Huawei P20 Battery Replacement, Rear Glass: step 1, image 1 of 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Huawei P20 Battery Replacement: step 2, image 1 of 3 Huawei P20 Battery Replacement: step 2, image 2 of 3 Huawei P20 Battery Replacement: step 2, image 3 of 3
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei P20 Battery Replacement: step 3, image 1 of 2 Huawei P20 Battery Replacement: step 3, image 2 of 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei P20 Battery Replacement: step 4, image 1 of 3 Huawei P20 Battery Replacement: step 4, image 2 of 3 Huawei P20 Battery Replacement: step 4, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the power button and rear camera make sure you only use the tip of the opening pick to avoid cutting the cable, smearing the lens or damaging the camera.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei P20 Battery Replacement: step 5, image 1 of 2 Huawei P20 Battery Replacement: step 5, image 2 of 2
    • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei P20 Battery Replacement: step 6, image 1 of 2 Huawei P20 Battery Replacement: step 6, image 2 of 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei P20 Battery Replacement: step 7, image 1 of 2 Huawei P20 Battery Replacement: step 7, image 2 of 2
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  8. Huawei P20 Battery Replacement, Motherboard Cover with NFC: step 8, image 1 of 2 Huawei P20 Battery Replacement, Motherboard Cover with NFC: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to peel the black tape next to the rear camera off the motherboard cover.
  9. Huawei P20 Battery Replacement: step 9, image 1 of 1
    • Remove the eight Phillips #00 screws (3.1 mm length).
  10. Huawei P20 Battery Replacement: step 10, image 1 of 2 Huawei P20 Battery Replacement: step 10, image 2 of 2
    • Use a pair of tweezers to peel the black foil at the bottom end of the phone off the loudspeaker.
  11. Huawei P20 Battery Replacement: step 11, image 1 of 2 Huawei P20 Battery Replacement: step 11, image 2 of 2
    • Slide an opening pick under the right side of the motherboard cover.
    • Rotate the opening pick slightly to pry up the motherboard cover.
  12. Huawei P20 Battery Replacement: step 12, image 1 of 3 Huawei P20 Battery Replacement: step 12, image 2 of 3 Huawei P20 Battery Replacement: step 12, image 3 of 3
    • Remove the motherboard cover with NFC.
  13. Huawei P20 Battery Replacement, Battery Disconnect: step 13, image 1 of 2 Huawei P20 Battery Replacement, Battery Disconnect: step 13, image 2 of 2
    • Use a spudger to pry up and disconnect the battery connector.
  14. Huawei P20 Battery Replacement, Daughterboard Cover: step 14, image 1 of 1
    • Remove the three Phillips #00 screws (3.2 mm length).
  15. Huawei P20 Battery Replacement: step 15, image 1 of 3 Huawei P20 Battery Replacement: step 15, image 2 of 3 Huawei P20 Battery Replacement: step 15, image 3 of 3
    Buy
    • Use a pair of tweezers to remove the daughterboard cover.
  16. Huawei P20 Battery Replacement, Charging Board with Main Flex: step 16, image 1 of 1
    • Remove the two Phillips #00 screws (3.2 mm length).
  17. Huawei P20 Battery Replacement: step 17, image 1 of 2 Huawei P20 Battery Replacement: step 17, image 2 of 2
    • Use a spudger to pry up and disconnect the main daughterboard connector from the daughterboard.
  18. Huawei P20 Battery Replacement: step 18, image 1 of 3 Huawei P20 Battery Replacement: step 18, image 2 of 3 Huawei P20 Battery Replacement: step 18, image 3 of 3
    Buy
    • Use a pair of tweezers to pry up and disconnect the connector of the white coax cable from the motherboard.
    • Unroute the white coax cable from the metal clips on the daughterboard and fold it to the side.
  19. Huawei P20 Battery Replacement: step 19, image 1 of 2 Huawei P20 Battery Replacement: step 19, image 2 of 2
    • Use a spudger to disconnect the main flex cable connector from the motherboard.
  20. Huawei P20 Battery Replacement: step 20, image 1 of 3 Huawei P20 Battery Replacement: step 20, image 2 of 3 Huawei P20 Battery Replacement: step 20, image 3 of 3
    • Remove the charging port and main flex cable by lifting it upwards and then pulling it in the direction of the motherboard.
  21. Huawei P20 Battery Replacement, Battery: step 21, image 1 of 3 Huawei P20 Battery Replacement, Battery: step 21, image 2 of 3 Huawei P20 Battery Replacement, Battery: step 21, image 3 of 3
    • Use a spudger to pry up and disconnect the power and volume button flex connector.
  22. Huawei P20 Battery Replacement: step 22, image 1 of 2 Huawei P20 Battery Replacement: step 22, image 2 of 2
    • Use a spudger to pry up and disconnect the display flex connector and fold the display cable out of your way to remove the battery.
  23. Huawei P20 Battery Replacement: step 23, image 1 of 1
    • Apply a heated iOpener to the screen to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes.
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  24. Huawei P20 Battery Replacement: step 24, image 1 of 3 Huawei P20 Battery Replacement: step 24, image 2 of 3 Huawei P20 Battery Replacement: step 24, image 3 of 3
    Plastic Cards
    $2.99
    Buy
    • Start to slide a plastic card under the bottom right corner of the battery to cut the adhesive.
    • Slide the plastic card along the right side of the battery to further release the adhesive. Gently start to pry up the battery while doing so.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for about two minutes to help weaken the adhesive.
  25. Huawei P20 Battery Replacement: step 25, image 1 of 3 Huawei P20 Battery Replacement: step 25, image 2 of 3 Huawei P20 Battery Replacement: step 25, image 3 of 3
    • Slide the plastic card under the whole upper part of the battery and cut the adhesive with it.
    • Slide the plastic card down to the bottom end of the battery to cut the remaining adhesive.
    • Use the plastic card to pry up the battery.
  26. Huawei P20 Battery Replacement: step 26, image 1 of 2 Huawei P20 Battery Replacement: step 26, image 2 of 2
    Tesa 61395 Tape
    $5.99
    Buy
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
22 other people completed this guide.
Dominik Schnabelrauch
248,777 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,888 Guides authored
3 Guide Comments
El mío no abre ni con soplete, he aplicado calor con secador del pelo, las cuñas se rompen, la ventosa se despega... no se mueve ni una micra. Al que inventó el USB C habría que colgarlo de los dedos de los pies y lo de las cacharros de cientos de euros cerrados como una caja de seguridad lo mismo.
Mic - Reply
Thank you so much!!!
Worked perfectly. Step 15 backwards is the biggest challenge.
Lukas Werz - Reply
Very great guide !!! Grande , ho fatto tutto alla perfezione , tranne incollaggio, ho messo poca colla
donato pantalena - Reply
Past 24 Hours: 12
Past 7 Days: 96
Past 30 Days: 361
All Time: 37,420
