Huawei P20 Charging Port with Main Flex Cable Replacement
  1. Huawei P20 Charging Port with Main Flex Cable Replacement, Rear Glass: step 1, image 1 of 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Huawei P20 Charging Port with Main Flex Cable Replacement: step 2, image 1 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 2, image 2 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 2, image 3 of 3
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei P20 Charging Port with Main Flex Cable Replacement: step 3, image 1 of 2 Huawei P20 Charging Port with Main Flex Cable Replacement: step 3, image 2 of 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei P20 Charging Port with Main Flex Cable Replacement: step 4, image 1 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 4, image 2 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 4, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the power button and rear camera make sure you only use the tip of the opening pick to avoid cutting the cable, smearing the lens or damaging the camera.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei P20 Charging Port with Main Flex Cable Replacement: step 5, image 1 of 2 Huawei P20 Charging Port with Main Flex Cable Replacement: step 5, image 2 of 2
    • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei P20 Charging Port with Main Flex Cable Replacement: step 6, image 1 of 2 Huawei P20 Charging Port with Main Flex Cable Replacement: step 6, image 2 of 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei P20 Charging Port with Main Flex Cable Replacement: step 7, image 1 of 2 Huawei P20 Charging Port with Main Flex Cable Replacement: step 7, image 2 of 2
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  8. Huawei P20 Charging Port with Main Flex Cable Replacement, Motherboard Cover with NFC: step 8, image 1 of 2 Huawei P20 Charging Port with Main Flex Cable Replacement, Motherboard Cover with NFC: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to peel the black tape next to the rear camera off the motherboard cover.
  9. Huawei P20 Charging Port with Main Flex Cable Replacement: step 9, image 1 of 1
    • Remove the eight Phillips #00 screws (3.1 mm length).
  10. Huawei P20 Charging Port with Main Flex Cable Replacement: step 10, image 1 of 2 Huawei P20 Charging Port with Main Flex Cable Replacement: step 10, image 2 of 2
    • Use a pair of tweezers to peel the black foil at the bottom end of the phone off the loudspeaker.
  11. Huawei P20 Charging Port with Main Flex Cable Replacement: step 11, image 1 of 2 Huawei P20 Charging Port with Main Flex Cable Replacement: step 11, image 2 of 2
    • Slide an opening pick under the right side of the motherboard cover.
    • Rotate the opening pick slightly to pry up the motherboard cover.
  12. Huawei P20 Charging Port with Main Flex Cable Replacement: step 12, image 1 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 12, image 2 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 12, image 3 of 3
    • Remove the motherboard cover with NFC.
  13. Huawei P20 Charging Port with Main Flex Cable Replacement, Battery Disconnect: step 13, image 1 of 2 Huawei P20 Charging Port with Main Flex Cable Replacement, Battery Disconnect: step 13, image 2 of 2
    • Use a spudger to pry up and disconnect the battery connector.
  14. Huawei P20 Charging Port with Main Flex Cable Replacement, Daughterboard Cover: step 14, image 1 of 1
    • Remove the three Phillips #00 screws (3.2 mm length).
  15. Huawei P20 Charging Port with Main Flex Cable Replacement: step 15, image 1 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 15, image 2 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 15, image 3 of 3
    Buy
    • Use a pair of tweezers to remove the daughterboard cover.
  16. Huawei P20 Charging Port with Main Flex Cable Replacement, Charging Board with Main Flex: step 16, image 1 of 1
    • Remove the two Phillips #00 screws (3.2 mm length).
  17. Huawei P20 Charging Port with Main Flex Cable Replacement: step 17, image 1 of 2 Huawei P20 Charging Port with Main Flex Cable Replacement: step 17, image 2 of 2
    • Use a spudger to pry up and disconnect the main daughterboard connector from the daughterboard.
  18. Huawei P20 Charging Port with Main Flex Cable Replacement: step 18, image 1 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 18, image 2 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 18, image 3 of 3
    Buy
    • Use a pair of tweezers to pry up and disconnect the connector of the white coax cable from the motherboard.
    • Unroute the white coax cable from the metal clips on the daughterboard and fold it to the side.
  19. Huawei P20 Charging Port with Main Flex Cable Replacement: step 19, image 1 of 2 Huawei P20 Charging Port with Main Flex Cable Replacement: step 19, image 2 of 2
    • Use a spudger to disconnect the main flex cable connector from the motherboard.
  20. Huawei P20 Charging Port with Main Flex Cable Replacement: step 20, image 1 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 20, image 2 of 3 Huawei P20 Charging Port with Main Flex Cable Replacement: step 20, image 3 of 3
    • Remove the charging port and main flex cable by lifting it upwards and then pulling it in the direction of the motherboard.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Dominik Schnabelrauch
210,026 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 61
All Time: 5,216
