Huawei P20 Pro Motherboard Cover and NFC Replacement
  1. Huawei P20 Pro Motherboard Cover and NFC Replacement, Rear Glass Replacement: step 1, image 1 of 1
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 2, image 1 of 3 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 2, image 2 of 3 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 2, image 3 of 3
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
  3. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 3, image 1 of 2 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 3, image 2 of 2
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
  4. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 4, image 1 of 3 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 4, image 2 of 3 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 4, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
  5. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 5, image 1 of 2 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 5, image 2 of 2
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
  6. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 6, image 1 of 3 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 6, image 2 of 3 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 6, image 3 of 3
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
  7. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 7, image 1 of 3 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 7, image 2 of 3 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 7, image 3 of 3
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  8. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 8, image 1 of 2 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 8, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
  9. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 9, image 1 of 2 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 9, image 2 of 2
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  10. Huawei P20 Pro Motherboard Cover and NFC Replacement, Motherboard Cover and NFC: step 10, image 1 of 1
    • Remove the nine Phillips #00 screws (3.4 mm length).
  11. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 11, image 1 of 3 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 11, image 2 of 3 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 11, image 3 of 3
    • Insert an opening pick under the left side of the motherboard cover that includes the NFC.
    • Slide the opening pick towards the top left corner of the phone and twist it to pry the cover out of its plastic clamps.
  12. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 12, image 1 of 2 Huawei P20 Pro Motherboard Cover and NFC Replacement: step 12, image 2 of 2
    • Repeat the previous process on the right side and twist the opening pick to pry up the motherboard cover.
  13. Huawei P20 Pro Motherboard Cover and NFC Replacement: step 13, image 1 of 1
    • Remove the motherboard cover.
3 other people completed this guide.
Dominik Schnabelrauch
211,728 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,063 Guides authored
One Comment
merci beaucoup pour votre travail. J'attire votre attention sur un point important : ne pas enlever le film en plastique noir de la partie métallique sans d’extrême précaution. . Il y a une petite partie conductive sur le coté gauche (sous le trou rond gris) qui se déchire facilement et qui n'est pas réparable sil elle est déchirée...
ederic.fr - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 64
All Time: 6,818
