Huawei P30 Pro Battery Replacement
  1. Huawei P30 Pro Battery Replacement, Rear Glass: step 1, image 1 of 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Huawei P30 Pro Battery Replacement: step 2, image 1 of 3 Huawei P30 Pro Battery Replacement: step 2, image 2 of 3 Huawei P30 Pro Battery Replacement: step 2, image 3 of 3
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei P30 Pro Battery Replacement: step 3, image 1 of 2 Huawei P30 Pro Battery Replacement: step 3, image 2 of 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei P30 Pro Battery Replacement: step 4, image 1 of 3 Huawei P30 Pro Battery Replacement: step 4, image 2 of 3 Huawei P30 Pro Battery Replacement: step 4, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the rear camera make sure you only use the tip of the opening pick to avoid smearing the lens or damaging the camera.
    • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei P30 Pro Battery Replacement: step 5, image 1 of 2 Huawei P30 Pro Battery Replacement: step 5, image 2 of 2
    • If the adhesive becomes hard to cut, it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei P30 Pro Battery Replacement: step 6, image 1 of 2 Huawei P30 Pro Battery Replacement: step 6, image 2 of 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei P30 Pro Battery Replacement: step 7, image 1 of 2 Huawei P30 Pro Battery Replacement: step 7, image 2 of 2
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Huawei P30 Pro Battery Replacement, Motherboard Cover with NFC & Charging Coil: step 8, image 1 of 1
    • Remove the ten Phillips #00 screws (4.3 mm length).
  9. Huawei P30 Pro Battery Replacement: step 9, image 1 of 2 Huawei P30 Pro Battery Replacement: step 9, image 2 of 2
    • Slide an opening pick under the black adhesive at the bottom right of the charging coil.
    • Carefully loosen the adhesive with the opening pick.
  10. Huawei P30 Pro Battery Replacement: step 10, image 1 of 2 Huawei P30 Pro Battery Replacement: step 10, image 2 of 2
    • Slide an opening pick under the black adhesive at the bottom left of the charging coil.
  11. Huawei P30 Pro Battery Replacement: step 11, image 1 of 2 Huawei P30 Pro Battery Replacement: step 11, image 2 of 2
    • Slide an opening pick under the left side of the motherboard cover.
    • Unhinge the left side of the motherboard cover by slightly rotating the opening pick.
  12. Huawei P30 Pro Battery Replacement: step 12, image 1 of 2 Huawei P30 Pro Battery Replacement: step 12, image 2 of 2
    • Push the motherboard cover out of the sockets at the top edge of the phone beginning with the top left corner.
    • Remove the motherboard cover including the NFC and charging coil.
  13. Huawei P30 Pro Battery Replacement, Battery Disconnect: step 13, image 1 of 2 Huawei P30 Pro Battery Replacement, Battery Disconnect: step 13, image 2 of 2
    • Use a spudger to pry up and disconnect the battery connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  14. Huawei P30 Pro Battery Replacement, Daughterboard Cover: step 14, image 1 of 1
    • Remove the five Phillips #00 screws (4.3 mm length).
    • Some of these screws may be hidden under adhesive. Carefully peel the adhesive to uncover these screws.
  15. Huawei P30 Pro Battery Replacement: step 15, image 1 of 2 Huawei P30 Pro Battery Replacement: step 15, image 2 of 2
    • Slide an opening pick under the top edge of the daughterboard cover.
    • Pry up and unhinge the daughterboard cover by slightly rotating the opening pick.
  16. Huawei P30 Pro Battery Replacement: step 16, image 1 of 2 Huawei P30 Pro Battery Replacement: step 16, image 2 of 2
    • Remove the daughterboard cover.
  17. Huawei P30 Pro Battery Replacement, Main Flex Cable Connectors: step 17, image 1 of 2 Huawei P30 Pro Battery Replacement, Main Flex Cable Connectors: step 17, image 2 of 2
    • Use a spudger to pry up and disconnect the left main flex cable connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Huawei P30 Pro Battery Replacement: step 18, image 1 of 2 Huawei P30 Pro Battery Replacement: step 18, image 2 of 2
    • Use a spudger to pry up and disconnect the right main flex cable connector from the motherboard.
  19. Huawei P30 Pro Battery Replacement, Charging Port with Main Flex Cable: step 19, image 1 of 2 Huawei P30 Pro Battery Replacement, Charging Port with Main Flex Cable: step 19, image 2 of 2
    • Use a spudger to pry up and disconnect the main flex cable connector from the daughterboard.
  20. Huawei P30 Pro Battery Replacement: step 20, image 1 of 2 Huawei P30 Pro Battery Replacement: step 20, image 2 of 2
    • Remove the main flex cable including the charging port by lifting it upwards and then pulling it in the direction of the motherboard.
  21. Huawei P30 Pro Battery Replacement, Battery: step 21, image 1 of 2 Huawei P30 Pro Battery Replacement, Battery: step 21, image 2 of 2
    • Peel the orange adhesive strip labeled with a 1 off the battery. The orange adhesive tape will rip along a small perforated line.
  22. Huawei P30 Pro Battery Replacement: step 22, image 1 of 2 Huawei P30 Pro Battery Replacement: step 22, image 2 of 2
    • Peel the orange adhesive strip labeled with a 2 off the battery. The orange adhesive tape will rip along a small perforated line.
  23. Huawei P30 Pro Battery Replacement: step 23, image 1 of 2 Huawei P30 Pro Battery Replacement: step 23, image 2 of 2
    • Peel the orange adhesive strip labeled with a 3 off the battery.
    • Pull up the orange adhesive strip to lift the battery out of its recess.
    • Although these new adhesive tabs are supposed to make the battery removal easier, these may require some force. In case you're having trouble removing the battery, you can apply a heated iOpener to the center of the display, to loosen the adhesive underneath.
  24. Huawei P30 Pro Battery Replacement: step 24, image 1 of 3 Huawei P30 Pro Battery Replacement: step 24, image 2 of 3 Huawei P30 Pro Battery Replacement: step 24, image 3 of 3
    • Swing the battery up to an upright position.
    • Peel the battery off the remaining adhesive.
    • Remove the battery.
    • During re-assembly, temporarily re-connect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
  25. Huawei P30 Pro Battery Replacement: step 25, image 1 of 2 Huawei P30 Pro Battery Replacement: step 25, image 2 of 2
    • Peel the battery's adhesive sticker off the midframe.
    • This step is mandatory if you are replacing the screen. However it is highly recommended to use a fresh adhesive sticker as well, when installing a new battery.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
13 other people completed this guide.
Dominik Schnabelrauch
248,306 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
13 Guide Comments
Hardware work is accurate. However, replacing original battery to Huawei P30 Pro it will generate a bootloop. Add next step to avoid this please. How to calibrate battery? Actually, how to pair new battery with the mainboard? Same problem occurs to P40lite and perhaps to Mate 30
maremestera - Reply
I also have the same problem, did you find a solution
Xarly -
you have to have the old battery first. I tried 2 batteries and I had the same problem you mentioned. Just put the new battery in its place and don't plug the wear of it, instead, you are going to put the old battery over the new battery and plug the wear of the old battery and turn on the device with the power cable on. Once it's turned on unplug it quickly and plunge the new battery wire. I know it sounds silly but I tried it and it worked. I think what happened is that you trick the phone by doing that. Btw, its hard to have the 2 batteries over each other but keep holding them.
nuno437 -
Hi, regarding the battery replacement, you will need to have the original battery serial number and copy it to the new one.
This can be done using ChimeraTool, but bear in mind you need to know what is your current firmware version. So before repair write down your firmware version ( example: VOG-L09 10.1.0.151(C636e9r2p4) ) and if it’s with the most recent update Chimera might not have it yet, so you will need to wait until they update.
Hope this helps!
Daniel Dimitrov - Reply
Can I contact you for help?
zlatko kovacic -
Past 24 Hours: 12
Past 7 Days: 69
Past 30 Days: 415
All Time: 53,559
