Huawei P8 Lite Battery Replacement
  1. Huawei P8 Lite Battery Replacement, Back Cover: step 1, image 1 of 2 Huawei P8 Lite Battery Replacement, Back Cover: step 1, image 2 of 2
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Battery Replacement: step 2, image 1 of 3 Huawei P8 Lite Battery Replacement: step 2, image 2 of 3 Huawei P8 Lite Battery Replacement: step 2, image 3 of 3
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Battery Replacement, Loudspeaker: step 3, image 1 of 1
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Battery Replacement: step 4, image 1 of 1
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Battery Replacement: step 5, image 1 of 1
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Battery Replacement, Battery: step 6, image 1 of 3 Huawei P8 Lite Battery Replacement, Battery: step 6, image 2 of 3 Huawei P8 Lite Battery Replacement, Battery: step 6, image 3 of 3
    • Remove the three Phillips #00 screws that hold the metal plate in place.
    • Remove the metal plate with a tweezer.
    • Unplug the battery flex connector with a spudger.
  7. Huawei P8 Lite Battery Replacement: step 7, image 1 of 2 Huawei P8 Lite Battery Replacement: step 7, image 2 of 2
    • To protect your motherboard during battery removal, you can reinstall the shield plate, allowing for safer prying.
    • Screw the three Phillips #00 screws back into the motherboard shield.
  8. Huawei P8 Lite Battery Replacement: step 8, image 1 of 2 Huawei P8 Lite Battery Replacement: step 8, image 2 of 2
    • Use a tweezer to loosen the adhesive strip and lift it up to give you an easy grip.
    • Gently pull out the adhesive strip. Don't pull it in a steep but in a flat angle and with caution. It can tear in two pieces easily.
    • If your phone is equipped with an NFC antenna continue with the next step to get it off. Skip the next step if it does not have an NFC antenna.
  9. Huawei P8 Lite Battery Replacement: step 9, image 1 of 3 Huawei P8 Lite Battery Replacement: step 9, image 2 of 3 Huawei P8 Lite Battery Replacement: step 9, image 3 of 3
    • Remove the Phillips #00 screw.
    • Use a tweezer to remove the plastic cover.
    • Carefully peel up the NFC tag and remove it.
    • When reassembling make sure to install the NFC antenna onto the new battery and connect it.
  10. Huawei P8 Lite Battery Replacement: step 10, image 1 of 3 Huawei P8 Lite Battery Replacement: step 10, image 2 of 3 Huawei P8 Lite Battery Replacement: step 10, image 3 of 3
    • There are three adhesive strips beneath the battery you'll need to undo. One under the top, the mid and the bottom of the battery.
    • Be very careful not to pry against the motherboard, you may damage surface mount components and lose functionality.
    • Use a Spudger to carefully start to pry out your battery.
  11. Huawei P8 Lite Battery Replacement: step 11, image 1 of 3 Huawei P8 Lite Battery Replacement: step 11, image 2 of 3 Huawei P8 Lite Battery Replacement: step 11, image 3 of 3
    • Undo the adhesive beneath the battery with the Spudger.
    • The easiest way to do so is by moving the Spudger in small movements like a lever.
  12. Huawei P8 Lite Battery Replacement: step 12, image 1 of 1
    Tool used on this step:
    Tesa 61395 Tape
    $8.95
    Buy
    • Remove the battery.
    • If you reinstalled the metal motherboard shield to protect the motherboard while prying, you will have to remove it to connect your new battery.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
To reassemble your device, follow these instructions in reverse order and apply new adhesive strips where necessary.
63 other people completed this guide.
Dominik Schnabelrauch
253,824 Reputation
682 Guides authored
iFixit EU Team Member of iFixit EU Team
Staff
37 Members
1,225 Guides authored
11 Guide Comments
Thanks for your sweet effort
Hussien - Reply Share
Très bon tuto ! Merci beaucoup :-)
ps : j’ai galéré a décollé la batterie
Jérôme Blanchart - Reply Share
Hat wunderbar funktioniert! Nun läuft mein P8 Lite wieder!
2711chrissi - Reply Share
One thing to be careful of that I just did, and screwed up my nieces phone.
You see that black square hole in the aluminium chassis under the battery? Yeah be very very careful when sticking your prying tool under the battery. The LCD us right behind it. Try and stay very far away from those holes in the chassis when you do your prying.
Her screen now has Horizontal and vertical lines right across the centre of the screen.
Sigh.
Terrence Wilson - Reply Share
Super Anleitung, Danke kann ich weiter empfehlen!
del Grosso - Reply Share
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 96
All Time: 86,678
