Huawei P8 Lite Earpiece Speaker Replacement
  1. Huawei P8 Lite Earpiece Speaker Replacement, Back Cover: step 1, image 1 of 2 Huawei P8 Lite Earpiece Speaker Replacement, Back Cover: step 1, image 2 of 2
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Earpiece Speaker Replacement: step 2, image 1 of 3 Huawei P8 Lite Earpiece Speaker Replacement: step 2, image 2 of 3 Huawei P8 Lite Earpiece Speaker Replacement: step 2, image 3 of 3
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Earpiece Speaker Replacement, Loudspeaker: step 3, image 1 of 1
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Earpiece Speaker Replacement: step 4, image 1 of 1
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Earpiece Speaker Replacement: step 5, image 1 of 1
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Earpiece Speaker Replacement, Motherboard: step 6, image 1 of 3 Huawei P8 Lite Earpiece Speaker Replacement, Motherboard: step 6, image 2 of 3 Huawei P8 Lite Earpiece Speaker Replacement, Motherboard: step 6, image 3 of 3
    • Remove the three Phillips #00 screws that hold the metal plate in place.
    • Remove the metal plate with a tweezer.
    • Unplug the battery flex connector with a spudger.
  7. Huawei P8 Lite Earpiece Speaker Replacement: step 7, image 1 of 1
    • Remove the two Torx T5 screws.
    • If there is a tamper evident sticker over your screws remove them to properly seat your driver.
    • Remove the five Phillips #00 screws.
  8. Huawei P8 Lite Earpiece Speaker Replacement: step 8, image 1 of 2 Huawei P8 Lite Earpiece Speaker Replacement: step 8, image 2 of 2
    • Carefully pry off the plastic cover on the left side. The NFC antenna contacts might be slightly glued to the cover.
    • Then remove the top cover.
  9. Huawei P8 Lite Earpiece Speaker Replacement: step 9, image 1 of 3 Huawei P8 Lite Earpiece Speaker Replacement: step 9, image 2 of 3 Huawei P8 Lite Earpiece Speaker Replacement: step 9, image 3 of 3
    • Remove the SIM card and SD card trays.
    • Disconnect the three plug connectors and one ZIF connector.
    • Unlock the ZIF connector by lifting the small black plastic lever.
  10. Huawei P8 Lite Earpiece Speaker Replacement: step 10, image 1 of 3 Huawei P8 Lite Earpiece Speaker Replacement: step 10, image 2 of 3 Huawei P8 Lite Earpiece Speaker Replacement: step 10, image 3 of 3
    • Remove the volume and power button cable.
    • Take out the motherboard by lifting the bottom part first.
    • Pay attention to the cables, so they don't rip when staying stuck to the motherboard.
    • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If this thermal pad broke or is too dried out you might want to replace it with a new one.
  11. Huawei P8 Lite Earpiece Speaker Replacement, Earpiece Speaker: step 11, image 1 of 2 Huawei P8 Lite Earpiece Speaker Replacement, Earpiece Speaker: step 11, image 2 of 2
    • Lift out the earpiece speaker of its recess with a tweezer.
    • It is glued in place with a mild adhesive, so you might need a little prying.
4 other people completed this guide.
Tobias Isakeit
119,540 Reputation
189 Guides authored
One Comment
Bonjour, sur le mien, il y a deux fils de cuivre très très fin, souder sur le haut parleur interne…
Sokarbur 32 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 3,383
