Huawei P8 Lite Motherboard Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Huawei P8 Lite Motherboard Replacement, Back Cover: step 1, image 1 of 2 Huawei P8 Lite Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Motherboard Replacement: step 2, image 1 of 3 Huawei P8 Lite Motherboard Replacement: step 2, image 2 of 3 Huawei P8 Lite Motherboard Replacement: step 2, image 3 of 3
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Motherboard Replacement, Loudspeaker: step 3, image 1 of 1
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Motherboard Replacement: step 4, image 1 of 1
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Motherboard Replacement: step 5, image 1 of 1
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Continue by removing the SIM and SD card trays on the side of the device.
  7. Huawei P8 Lite Motherboard Replacement: step 7, image 1 of 3 Huawei P8 Lite Motherboard Replacement: step 7, image 2 of 3 Huawei P8 Lite Motherboard Replacement: step 7, image 3 of 3
    • Remove the two Torx T5 screws. One may be cover with a liquid indicator.
    • Remove the five Phillips #000 screws.
    • Take away both securing brackets covering the motherboard.
    • If your phone has an NFC antenna, taking away the cover will automatically free its flex connector from the motherboard.
  8. Huawei P8 Lite Motherboard Replacement: step 8, image 1 of 1
    • Remove the three Phillips #000 screws on the silver panel.
  9. Huawei P8 Lite Motherboard Replacement: step 9, image 1 of 2 Huawei P8 Lite Motherboard Replacement: step 9, image 2 of 2
    • Carefully separate the four connectors holding the motherboard in place.
    • Remove the motherboard from the device.
6 other people completed this guide.
John Poffenberger
356 Reputation
3 Guides authored
USF Tampa, Team 1-1, Kass Spring 2017 Member of USF Tampa, Team 1-1, Kass Spring 2017
USFT-KASS-S17S1G1
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,104
