Huawei P9 Charging Board Replacement
  1. Huawei P9 Charging Board Replacement, Back Cover: step 1, image 1 of 3 Huawei P9 Charging Board Replacement, Back Cover: step 1, image 2 of 3 Huawei P9 Charging Board Replacement, Back Cover: step 1, image 3 of 3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Charging Board Replacement: step 2, image 1 of 2 Huawei P9 Charging Board Replacement: step 2, image 2 of 2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Charging Board Replacement, Fingerprint sensor: step 3, image 1 of 2 Huawei P9 Charging Board Replacement, Fingerprint sensor: step 3, image 2 of 2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Charging Board Replacement, lower section: step 4, image 1 of 3 Huawei P9 Charging Board Replacement, lower section: step 4, image 2 of 3 Huawei P9 Charging Board Replacement, lower section: step 4, image 3 of 3
    • Undo the three Phillips #00 screws.
    • Disconnect the loudspeaker flex connector.
    • Carefully remove the metal bracket.
    • Mind the adhesive underneath that might stick to the headphone connector.
  5. Huawei P9 Charging Board Replacement: step 5, image 1 of 3 Huawei P9 Charging Board Replacement: step 5, image 2 of 3 Huawei P9 Charging Board Replacement: step 5, image 3 of 3
    • Disconnect the motherboard flex cable and the antenna cable.
    • Unplug the headphone jack connector.
  6. Huawei P9 Charging Board Replacement, Charging Board: step 6, image 1 of 1
    • Now you can easily remove the charging board.
8 other people completed this guide.
Dominik Schnabelrauch
228,969 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,413 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 7
All Time: 7,273
