Huawei P9 Lite Loudspeaker Replacement
  1. Huawei P9 Lite Loudspeaker Replacement, Back Cover: step 1, image 1 of 2 Huawei P9 Lite Loudspeaker Replacement, Back Cover: step 1, image 2 of 2
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Loudspeaker Replacement: step 2, image 1 of 1
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Loudspeaker Replacement: step 3, image 1 of 1
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: step 4, image 1 of 3 Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: step 4, image 2 of 3 Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: step 4, image 3 of 3
    • On the bottom of the phone remove the following screws:
    • Three 2.9 mm Phillips #00 screws
    • Four 3.8 mm Phillips #00 screws
    • Now you can grab the loudspeaker unit and take it out.
12 other people completed this guide.
Tobias Isakeit
129,939 Reputation
189 Guides authored
3 Guide Comments
Was replacing the charging system bt now people can not hear me unless I put on loud speaker
dtotisitswe - Reply
Same problem here. Any help?
fabio9999 -
Sir hy how are you. Sir p9lite song speaker not working.
Sufyan Raja - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 32
All Time: 10,665
