Huawei Pronto LTE Battery Replacement
  1. Huawei Pronto LTE Battery Replacement, Battery: step 1, image 1 of 2 Huawei Pronto LTE Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the back cover of your Huawei Pronto LTE using an opening tool.
    • Lift the back cover off of the device after the four corners are unlatched.
  2. Huawei Pronto LTE Battery Replacement: step 2, image 1 of 3 Huawei Pronto LTE Battery Replacement: step 2, image 2 of 3 Huawei Pronto LTE Battery Replacement: step 2, image 3 of 3
    • Remove the 15 screws on the back of the device using a Phillips #000 screwdriver.
    • Hold the device in place while you are doing this step.
    • Lift the inner cover gently by using a spudger.
  3. Huawei Pronto LTE Battery Replacement: step 3, image 1 of 3 Huawei Pronto LTE Battery Replacement: step 3, image 2 of 3 Huawei Pronto LTE Battery Replacement: step 3, image 3 of 3
    • Detach the yellow latches along the sides to remove the motherboard.
  4. Huawei Pronto LTE Battery Replacement: step 4, image 1 of 3 Huawei Pronto LTE Battery Replacement: step 4, image 2 of 3 Huawei Pronto LTE Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Ensure that all latches are detached and that there are no extra screws to avoid damaging the motherboard.
    • Use tweezers to gently remove the motherboard from the device.
  5. Huawei Pronto LTE Battery Replacement: step 5, image 1 of 3 Huawei Pronto LTE Battery Replacement: step 5, image 2 of 3 Huawei Pronto LTE Battery Replacement: step 5, image 3 of 3
    • The battery should be revealed once the motherboard is removed.
    • Lift the battery from the top left corner.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 812
