Huawei SnapTo G-620 Motherboard Replacement
  1. Huawei SnapTo G-620 Motherboard Replacement, Battery: step 1, image 1 of 3 Huawei SnapTo G-620 Motherboard Replacement, Battery: step 1, image 2 of 3 Huawei SnapTo G-620 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
    • Remove all fifteen 4mm Phillips J00 screws on the back panel.
    • Using a metal spudger or your fingernail, remove the back panel.
  2. Huawei SnapTo G-620 Motherboard Replacement: step 2, image 1 of 1
    • Remove the pictured 4mm Phillips J00 screw.
  3. Huawei SnapTo G-620 Motherboard Replacement: step 3, image 1 of 2 Huawei SnapTo G-620 Motherboard Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to remove the pictured flat-top connector.
  4. Huawei SnapTo G-620 Motherboard Replacement: step 4, image 1 of 1
    • Remove the battery.
  5. Huawei SnapTo G-620 Motherboard Replacement, Motherboard: step 5, image 1 of 2 Huawei SnapTo G-620 Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Using the plastic opening tool remove the camera.
  6. Huawei SnapTo G-620 Motherboard Replacement: step 6, image 1 of 3 Huawei SnapTo G-620 Motherboard Replacement: step 6, image 2 of 3 Huawei SnapTo G-620 Motherboard Replacement: step 6, image 3 of 3
    • Use the plastic opening tools to remove all the remaining flat-top connectors
  7. Huawei SnapTo G-620 Motherboard Replacement: step 7, image 1 of 3 Huawei SnapTo G-620 Motherboard Replacement: step 7, image 2 of 3 Huawei SnapTo G-620 Motherboard Replacement: step 7, image 3 of 3
    • Using the spudger, pry open the zif connector, and remove the cable.
  8. Huawei SnapTo G-620 Motherboard Replacement: step 8, image 1 of 1
    • Using flat-side of spudger, remove the motherboard.
Brian Omer Uzan
401 Reputation
4 Guides authored
USF Tampa, Team S2-G6, Nance Fall 2017 Member of USF Tampa, Team S2-G6, Nance Fall 2017
USFT-NANCE-F17S2G6
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 355
