Huawei Watch 2 Opening Procedure
  1. Huawei Watch 2 Opening Procedure, Huawei Watch 2 Opening Procedure: step 1, image 1 of 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  2. Huawei Watch 2 Opening Procedure: step 2, image 1 of 1
    • Remove the four Torx T2 screws (4.5 mm length).
  3. Huawei Watch 2 Opening Procedure: step 3, image 1 of 3 Huawei Watch 2 Opening Procedure: step 3, image 2 of 3 Huawei Watch 2 Opening Procedure: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the four plastic covers sitting next to the watch band holders.
  4. Huawei Watch 2 Opening Procedure: step 4, image 1 of 3 Huawei Watch 2 Opening Procedure: step 4, image 2 of 3 Huawei Watch 2 Opening Procedure: step 4, image 3 of 3
    • Insert an opening tool into the gap between the back cover and the watch case at the bottom edge of the back cover.
    • Use the opening tool to pry up the back cover of the Huawei Watch 2.
    • Do not remove the back cover assembly all the way yet—it's still connected to the mainboard.
  5. Huawei Watch 2 Opening Procedure: step 5, image 1 of 2 Huawei Watch 2 Opening Procedure: step 5, image 2 of 2
    • Carefully fold the back cover assembly to the opposite side of the two watch crowns.
To reassemble your Huawei Watch 2, follow these instructions in reverse order.
4 other people completed this guide.
Dominik Schnabelrauch
249,446 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,927 Guides authored
3 Guide Comments
Tengo un problema con el reloj que no me esta haciendo las mediciones de la frecuencia cardiaca, como se cambia y donde se consigue ese sensor.
Gracias
Cesar Carrillo - Reply
Hi, any ideas if you can get the rubber membrane that goes behind the buttons? One of mine has worn away so had to swap them so the main button actually worked. Just bottom button now not working..
Andy Andy - Reply
A carcaça do meu HUAWEI WATCH 2 quebrou aonde o pino da pulseira encaixa. Como conseguir uma para reposição? Grato.
Del Credere Imóveis - Reply
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 94
All Time: 7,377
