Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch and 3 other contributors
Last updated on August 20, 2024
40 minutes - 1 hour
Moderate
Introduction
Go to step 1
Use this guide to replace the motherboard & daughterboard in the Huawei Watch GT 2 (46 mm).
Tools
Show more…
  1. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Remove the watch band: step 1, image 1 of 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Unfasten the screws: step 2, image 1 of 1
    • Remove the four 3.7 mm-long Torx T2 screws.
  3. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Insert a spudger: step 3, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Insert a spudger: step 3, image 2 of 2
    • Insert the edge of a spudger into the middle loudspeaker opening at the top edge of your watch.
  4. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Pry up the back cover assembly: step 4, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Pry up the back cover assembly: step 4, image 2 of 2
    • The plastic clamps holding the back cover in place sit very tight and may require some force during the prying procedure.
    • Use the spudger to pry up the back cover assembly of your Huawei watch GT 2.
    • Don't try to remove the back cover assembly all the way yet, it's still connected to the motherboard.
  5. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 5, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 5, image 2 of 2
    • Carefully swing the back cover assembly open to an upward position.
  6. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Unfasten the screws: step 6, image 1 of 1
    • Remove the two 2.3 mm-long Phillips #00 screws.
  7. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Remove the metal shield: step 7, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Remove the metal shield: step 7, image 2 of 2
    • Use a pair of tweezer to remove the metal shield covering the multi-purpose flex connector.
  8. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the flex cable: step 8, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the flex cable: step 8, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the multi-purpose flex connector.
  9. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Separate the back cover assembly: step 9, image 1 of 1
    • Separate the back cover assembly from the watch case.
  10. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the main flex cable: step 10, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the main flex cable: step 10, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the main flex cable from the daughterboard.
  11. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the watch buttons: step 11, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the watch buttons: step 11, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the watch buttons flex cable from the daughterboard.
  12. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Lift the daughterboard: step 12, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Lift the daughterboard: step 12, image 2 of 2
    • Use the flat end of a spudger to lift the right edge of the daughterboard off its socket.
  13. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Remove the daughterboard: step 13, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Remove the daughterboard: step 13, image 2 of 2
    Tool used on this step:
    • Use a pair of tweezers to remove the daughterboard.
  14. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 14, image 1 of 1
    • Remove the three 2.3 mm-long Phillips #00 screws.
  15. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 15, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 15, image 2 of 2
    • Use a pair of tweezers to remove the metal shield covering the display connectors.
  16. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 16, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 16, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the left display flex cable.
  17. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 17, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 17, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the right display flex cable.
  18. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 18, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 18, image 2 of 2
    • Use a pair of tweezers to carefully peel the watch button flex cable off the motherboard and fold it to the side.
  19. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 19, image 1 of 2 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: step 19, image 2 of 2
    • Remove the motherboard.
14 other people completed this guide.
230,363 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,540 Guides authored
6 Comments
Fine, the step 15 is quite difficult, because there is a pin into the U near the edge ... I did have to remove by the middle of the shield and pry It
Good job
Bruno Dujardin - Reply
Tutoriel très bien détaillé, j'ai suivi toutes les étapes sans problème, merci pour cete aide précieuse.
Walter - Reply
Many thanks, worked perfect for me. When prying open the watch, I put it face up on the table and placed the side with the speaker on 5 mm thick solid elevation. I then pressed down with a spudger using the middle speaker opening as insertion point.
Rolbinho - Reply
Re-assembled - no issues. But the capacitive touch screen does not work now - what do I need to check? Everything appears to be back in its place.
Paul - Reply
Dommage qu il n y ai pas d explication sur comment retirer la batterie😢… elle est soudée et donc pas remplaçable 😢 pas la peine de commander une batterie!
Matt MacFly - Reply
Past 24 Hours: 5
Past 7 Days: 46
Past 30 Days: 196
All Time: 12,459
