Introduction
A watch's battery is responsible for maintaining the life-time of the watch. Therefore, a damaged battery will take away from the enjoyment of the watch. This guide highlights the steps required to replace the Huawei Jewel Battery. It can be a relatively difficult process, so follow all steps carefully.
Begin by laying the watch on a flat, smooth surface.
Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
Use the spudger or opening pick to carefully lift the battery from the watch.
20 other people completed this guide.
8 Comments
Any idea where one can purchase the actual battery? I can’t find one anywhere.
@Chris wellings: i was able to find one on ebay. Arrived quite quickly. And you definitely need a T2(not 3) screwdriver to open up the watch.
Also found one on eBay. I was replacing the battery on the standard Huawei Watch (W1) and this guide was really helpful.
