Huawei Y300 Charging Port Replacement
  1. Huawei Y300 Charging Port Replacement, Charging Port: step 1, image 1 of 2 Huawei Y300 Charging Port Replacement, Charging Port: step 1, image 2 of 2
    • Remove the back plate by hand. There is a small indent on the bottom of the phone to pry open.
  2. Huawei Y300 Charging Port Replacement: step 2, image 1 of 1
    • Lift up and remove the battery.
  3. Huawei Y300 Charging Port Replacement: step 3, image 1 of 2 Huawei Y300 Charging Port Replacement: step 3, image 2 of 2
    • Use a T4 Torx screwdriver to remove the 8 screws along the outer edge of the case.
  4. Huawei Y300 Charging Port Replacement: step 4, image 1 of 2 Huawei Y300 Charging Port Replacement: step 4, image 2 of 2
    • Using the plastic opening tool, pry the screen from the casing. Insert the tool between the case and screen to pry the pieces apart.
    • Take care to not damage the screen or case.
  5. Huawei Y300 Charging Port Replacement: step 5, image 1 of 2 Huawei Y300 Charging Port Replacement: step 5, image 2 of 2
    • Use a soldering iron to desolder the four connections to the charging port.
    • For information regarding how to properly solder, click the following link. How To Solder and Desolder Connections.
3 other people completed this guide.
Alec Schory
193 Reputation
1 Guide authored
IUPUI, Team S3-G5, Harley Spring 2019 Member of IUPUI, Team S3-G5, Harley Spring 2019
IUPUI-HARLEY-S19S3G5
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,097
