Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement
Video Overview
  1. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: step 1, image 1 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: step 1, image 2 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: step 1, image 3 of 3
    • Turn off the device
    • Remove the sim tray
  2. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: step 2, image 1 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: step 2, image 2 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: step 2, image 3 of 3
    • Use Plastic tool to separate the back cover
    • With a Phillips screwdriver remove two black screws and the battery flex connector shield
    • Disconnect the battery and the finger print sensor flex cable
  3. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: step 3, image 1 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: step 3, image 2 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: step 3, image 3 of 3
    • Remove all screws from the top of the logic board
    • Remove the shield covering the camera connectors
    • Remove the screws and the plastic cover at the bottom of the device
    • Be careful! Different colored screws have different size
  4. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: step 4, image 1 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: step 4, image 2 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: step 4, image 3 of 3
    • Disconnect the Screen Flex cable
    • Remove the logic board
    • Note that at the bottom side of board is attached to the display with double-sided tape
  5. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: step 5, image 1 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: step 5, image 2 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: step 5, image 3 of 3
    • Now you have to transfer:
    • Receiver
    • Proximity sensor
    • Volume buttons flex
    • Vibration
    • Battery
11 other people completed this guide.
ZFix
191,882 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
One Comment
Can i get video guide
filmon - Reply
Past 24 Hours: 9
Past 7 Days: 36
Past 30 Days: 161
All Time: 6,863
